Page 14 of 74 FirstFirst ... 1213141516 ... LastLast
Results 131 to 140 of 734
Thread: Jay see 1997 GU build up
  1. #131
    Pop in , in the morning only giving the troll a bit of a clean...
    and yes I have your mobile
    You'll love the red digital, take mine for a burn around the block
    Well see got some things to do in the morning. Then is sleep time as got work tomorrow night.
  2. The Following User Says Thank You to jay see For This Useful Post:
    BigRAWesty (2nd March 2016)
  3. #132
    Tried to get a pic at night for you they are awesome a very mellow red I have not idea why they flared in the pic
    But its just a subtle red light. I absolutely love it
  4. #133
    Thanks John, but I'm more concerned about how they look in bright sunny conditions.
  5. #134
    this was in full sunlight as I said very easy to read
  6. The Following User Says Thank You to threedogs For This Useful Post:
    jay see (6th March 2016)
  7. #135
    I'm finally going to do something about my radiator.
    Question is there seems to be a few that state a bleed pipe. Where would I find this on my current on TB45 auto.
    Don't recall seeing one.
    Never mind, I've find a direct replacement.
  8. #136
    Dont you have a bleed point at the back of the motor??
  9. #137
    Not that I'm aware of. I've always done the coke bottle trick.
  10. #138
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Cant think which pipe it is but should come of the heater hose with a blue or black cap
    make sure you don't get the air con pipes it is at the back near the firewall
  11. The Following User Says Thank You to Sir Roofy For This Useful Post:
    jay see (29th March 2016)
  12. #139
    Yeah just park up hill and idle it for 1/2 hr squeeze the top hose every now and then to force bubbles out.
    If you are on gas crack the hose fittings on the condenser, air always gets trapped there
    Ill double check manual for bleed point
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #140
    Quote Originally Posted by roofy View Post
    Thanks roofy. Will have a good look when I pull it out.
    Just spoke to a radiator place and some come with a bleed pipe port. These don't have a overflow hose or bottle. It bleeds back into the system. Mine has a overflow bottle, so I'm guessing that there should be a bleed valve somewhere.
    He priced me at $330.
  15. The Following User Says Thank You to jay see For This Useful Post:
    Sir Roofy (29th March 2016)
