Page 18 of 33 FirstFirst ... 1617181920 ... LastLast
Results 171 to 180 of 323
Thread: Roofy needs our help ..... Can the forum come to the rescue !!!!
  1. #171
    Hardcore
    Coffs Harbour
    G'day AB and Mudski,
    My wife has electronically deposited our $100.00 into Mudski's account for Roofy and Jane, $50.00 for tickets and $50.00 for the fund. ANZ Receipt number 545182
    If we are lucky enough to win a prize, we request that the prize goes to Roofy and Jane.
    PS, i will express post tomorrow to mudski, the formula 1 JORDAN/HONDA racing team mechanic shirt. This is also to be raffled off with the other prizes.
    Regards
    PMC
    The halls been rented the bands been paid, time to see you dance!
  2. The Following 2 Users Say Thank You to PMC For This Useful Post:
    mudski (28th February 2016), Sir Roofy (28th February 2016)
  3. #172
    Jan 2016
    You're welcome to use our place if it's not too far in the sticks. Plenty of shed space and camping room. The beast will fit in Katrols shed. Or the big shed.
    I wish my house had a shed big enough to fit a Patrol, and that wasn't even "the big shed"
  4. The Following 2 Users Say Thank You to pjhsv For This Useful Post:
    katwoman (28th February 2016), Sir Roofy (28th February 2016)
  5. #173
    Nov 2010
    Getting a life...
    38 Post(s)
    I thinkk Kats plaec next weekend then i can attend, and br the responsible alchomoholic
    This is why I live in the sticks. To keep people like you away.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  6. The Following 2 Users Say Thank You to katwoman For This Useful Post:
    growler2058 (28th February 2016), Stropp (28th February 2016)
  7. #174
    Feb 2011
    Shed
    45 Post(s)
  8. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    katwoman (28th February 2016), Stropp (28th February 2016)
  9. #175
    Bringing some chilli over ?, when you get rid of that F&#c$king bolt,
    you should frame it and stick it above your work bench or near the fridge lol
  10. #176
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by PMC View Post
    G'day trendsetters,
    On a serious note, if we are going to spend between $3000 and $4000 for a motor for Roofy, then i think we need to discount a secondhand engine.
    I have located the following motor listed below is situated in Clayton South Victoria, it is a fully reconditioned engine with 12 months warranty, the mob wants $4600 exchange. I think we could contact these folks they might come to the party and let us have the motor for around $3500 or $4000. Plus the motor also comes with a brand new head and 12 months warranty. The blokes business number is 0400 033 377. I think you folks need to contact this chap ASAP to see what deal the bloke might offer.
    Hi there, Up for sale I have aFully Reconditioned ZD30 Engine for sale on exchange basis. Happy to let youpickup / post this engine prior to handing over me your existing faulty engine if you are happy to pay an additional $700 core deposit (fully refundable once I receive your old/faulty engine)
    This engine is only suited for standard diesel engines and is not suited for commonrail injection system.
    Please read through the listing carefully to see all the added extras that’s on offer with this engine, as most of the extras are only offered by us!
    This engine comes with a Brand New Head not a previously cracked / welded head!!
    This engine has been completely stripped, all parts hydrowashed.
    Cylinders are individually bored to manufacturers specifications than diamond honed & plateu finished (highest quality finish available on the market).
    Cylinder head contact surface / Deck has been surfaced(milled)
    Conrods checked for twist & straightness
    Cam shaft as well as the balance shafts checked for cracks, straightness than linished
    Crank shaft checked for straightness & cracks, journals measured than compared to factories allowed measurements, if its within specks linished, if not; journals are ground to factory specs using Schou CrankshaftGrinder
    After the machining of all parts they were washed again prior to assembly
    Brand New Cylinder Head was assembled with reconditioned valves, springs, caps, collets and buckets, valve clearances set to manufacturer’s specifications using brand new shims.
    Oil cooler has been pulled apart, hydro washed, all gaskets and seals replaced during assembly and vacuum tested prior to fitment.
    This engine was assembled using all of the following brand new components:
    Cylinder head
    Pistons, Pin’s and Rings
    Main bearings
    Bigend bearings
    Timing Chain & Timing Chain Tensioner
    Complete Gasket Set
    Head Bolts
    Water Pump
    Rear Main seal
    Glow Plugs
    Injector Seals
    Glow Plug Seals
    This engine comes with 12 months / unlimited km's warranty
    Please note this engine is also available on our shop floor as well as other market places, so it may be sold prior to your purchase / end of this listing. To confirm availability please contact me and I will let you know the availibility.
    Item islocated in Clayton South Victoria, I'm happy to freight these engines atadditional cost Australiawide! Any Questions or simply call me on 0400 033 377.
    ive read this again and it sounds like a good way to go. It doesn't say anything about a turbo ?.
    This is the way we would like to go especially as it has a warranty. Can we look into this further? Thanks
  11. The Following 5 Users Say Thank You to Sir Roofy For This Useful Post:
    Bob (28th February 2016), Irish (28th February 2016), katwoman (28th February 2016), mudnut (28th February 2016), Rossco (28th February 2016)
  12. #177
    84 Post(s)
    Very well, roofy. We'd better get your old manifold off and cleaned, your turbo checked and your injectors cleaned and tested. He doesn't mention injectors, except for new seals.
  13. The Following User Says Thank You to mudnut For This Useful Post:
  14. #178
    Nov 2010
    Getting a life...
    38 Post(s)
    SteveO is making a donation of a $200 gift voucher from Autobarn to roofy and JaneO that could be used for oil, filters ect.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  15. The Following 8 Users Say Thank You to katwoman For This Useful Post:
    Bob (28th February 2016), mudski (28th February 2016), Rossco (28th February 2016), Sir Roofy (28th February 2016), Stropp (28th February 2016), TPC (28th February 2016), Winnie (28th February 2016), Woof (28th February 2016)
  16. #179
    Nov 2010
    Getting a life...
    38 Post(s)
    Quote Originally Posted by roofy View Post
    It would be worth putting new clutch and pressure plate in and machine flywheel while engine is out.
    We can organise trade price.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  17. The Following 6 Users Say Thank You to katwoman For This Useful Post:
    Bob (28th February 2016), Rossco (28th February 2016), Sir Roofy (28th February 2016), Stropp (28th February 2016), threedogs (28th February 2016), Woof (28th February 2016)
  18. #180
    Nov 2010
    Getting a life...
    38 Post(s)
    The onsite deluxe cabins, if needed.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  19. The Following 5 Users Say Thank You to katwoman For This Useful Post:
    BigRAWesty (29th February 2016), Bob (28th February 2016), mudnut (28th February 2016), TPC (28th February 2016), Woof (28th February 2016)
