Page 15 of 33 FirstFirst ... 1314151617 ... LastLast
Results 141 to 150 of 323
Thread: Roofy needs our help ..... Can the forum come to the rescue !!!!
  1. #141
    Quote Originally Posted by roofy View Post
    Looks like a barby at my place coming up
    I would like to help out on the day, hopefully it on a weekend that I'm not working.
    Also if you guys need someone to do some running around to pick up bits n pieces just yell out. Probably the only benefit of doing shift work.
  2. #142
    Thomastown, Melbourne
    6 Post(s)
    What i am thinking is maybe we get hold of the car and a few of us do the engine swap or rebuild or what ever the case may be then once the car is up and running we have a big meet up to celebrate. ...
    Too many distractions when there is a tonne of people around and things can get missed.
    Matty please shed some light on what you are thinking. . What is in ferntree gully.
  3. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    jay see (27th February 2016)
  4. #143
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by Bloodyaussie View Post
    Here is a pic of the logo... would only cover lower half of side rear glass.
    Fine if you dont feel comfortable with it.
    If Roofy is not comfortable with it and if your boss is ok with it I will throw them on my car if it secures them an extra 200 bucks.
    Instead of a sticker maybe Andy could do a free vendor thread for them on here for a couple of years, reckon it would get more publicity on the net then a sticker on the a side of a car
  5. The Following 4 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    BigRAWesty (27th February 2016), Bloodyaussie (27th February 2016), Sir Roofy (27th February 2016), Stropp (27th February 2016)
  6. #144
    6 Post(s)
    Not a bad idea Todd.... worth further discussion at least.
  7. The Following 3 Users Say Thank You to Bloodyaussie For This Useful Post:
    BigRAWesty (27th February 2016), NissanGQ4.2 (27th February 2016), Sir Roofy (27th February 2016)
  8. #145
    North brissy
    I think lucus30 is..?
    Why...
    There is a nissan dealer there who usually stocks quite a few crate engines. They may be worth a call or drop in to see if they have anything.
    A brand new engine will come with warranty plus you avoid some of the issues that can be had with a rebuild.
  9. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Rossco (27th February 2016), Sir Roofy (27th February 2016)
  10. #146
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    I can go have a look. Um I'll try to head up Monday
    Lucus30's 1999 GU ST TB45E
  11. The Following User Says Thank You to lucus30 For This Useful Post:
  12. #147
    Hardcore
    Coffs Harbour
    G'day trendsetters,
    On a serious note, if we are going to spend between $3000 and $4000 for a motor for Roofy, then i think we need to discount a secondhand engine.
    I have located the following motor listed below is situated in Clayton South Victoria, it is a fully reconditioned engine with 12 months warranty, the mob wants $4600 exchange. I think we could contact these folks they might come to the party and let us have the motor for around $3500 or $4000. Plus the motor also comes with a brand new head and 12 months warranty. The blokes business number is 0400 033 377. I think you folks need to contact this chap ASAP to see what deal the bloke might offer.
    Hi there, Up for sale I have aFully Reconditioned ZD30 Engine for sale on exchange basis. Happy to let youpickup / post this engine prior to handing over me your existing faulty engine if you are happy to pay an additional $700 core deposit (fully refundable once I receive your old/faulty engine)
    This engine is only suited for standard diesel engines and is not suited for commonrail injection system.
    Please read through the listing carefully to see all the added extras that’s on offer with this engine, as most of the extras are only offered by us!
    This engine comes with a Brand New Head not a previously cracked / welded head!!
    This engine has been completely stripped, all parts hydrowashed.
    Cylinders are individually bored to manufacturers specifications than diamond honed & plateu finished (highest quality finish available on the market).
    Cylinder head contact surface / Deck has been surfaced(milled)
    Conrods checked for twist & straightness
    Cam shaft as well as the balance shafts checked for cracks, straightness than linished
    Crank shaft checked for straightness & cracks, journals measured than compared to factories allowed measurements, if its within specks linished, if not; journals are ground to factory specs using Schou CrankshaftGrinder
    After the machining of all parts they were washed again prior to assembly
    Brand New Cylinder Head was assembled with reconditioned valves, springs, caps, collets and buckets, valve clearances set to manufacturer’s specifications using brand new shims.
    Oil cooler has been pulled apart, hydro washed, all gaskets and seals replaced during assembly and vacuum tested prior to fitment.
    This engine was assembled using all of the following brand new components:
    Cylinder head
    Pistons, Pin’s and Rings
    Main bearings
    Bigend bearings
    Timing Chain & Timing Chain Tensioner
    Complete Gasket Set
    Head Bolts
    Water Pump
    Rear Main seal
    Glow Plugs
    Injector Seals
    Glow Plug Seals
    This engine comes with 12 months / unlimited km's warranty
    Please note this engine is also available on our shop floor as well as other market places, so it may be sold prior to your purchase / end of this listing. To confirm availability please contact me and I will let you know the availibility.
    Item islocated in Clayton South Victoria, I'm happy to freight these engines atadditional cost Australiawide! Any Questions or simply call me on 0400 033 377.
    The halls been rented the bands been paid, time to see you dance!
  13. The Following 6 Users Say Thank You to PMC For This Useful Post:
    Bloodyaussie (27th February 2016), growler2058 (27th February 2016), Irish (27th February 2016), macca (29th February 2016), Sir Roofy (27th February 2016), Stropp (27th February 2016)
  14. #148
    Quote Originally Posted by PMC View Post
    G'day trendsetters,
    Yeah think i saw this same ad on flea bay and was thinking something along these lines as an option. I can ring or drop in to lilydale nissan see if the have a price on a crate motor. We get our work navara serviced there and the service is excellent which can be rare for a dealer! Can give ftg a call too.
  15. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    PMC (27th February 2016), Sir Roofy (27th February 2016)
  16. #149
    Does the caravan sticker come in white as well, not going show up on a dark paint job
    Angled up across the rear window would look OK
  17. #150
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    G'day trendsetters,
    Cylinder head
    Main bearings
    Bigend bearings
    Complete Gasket Set
    Head Bolts
    Water Pump
    Rear Main seal
    Glow Plugs
    Injector Seals
    Glow Plug Seals
    Now this is a good idea this or another one as its going to be from the members of the forum
    if the motor comes with this much warranty it would be acceptable by the members and myself
    if there are enough funds in the kitty.Lets see if I can clock up another 282000 ks
  18. The Following 3 Users Say Thank You to Sir Roofy For This Useful Post:
    PMC (27th February 2016), Rossco (27th February 2016), Woof (27th February 2016)
