Page 610 of 1057 FirstFirst ... 608609610611612 ... LastLast
Results 6,091 to 6,100 of 10562
  1. #6091
    Finally got around to cutting the square for my dual carling switch holder.
    This will house my winch on/off and winch in/out switches
    Winch in/out still to arrive
    Looks wonky
  2. The Following User Says Thank You to Clunk For This Useful Post:
    BigRAWesty (21st February 2016)
  3. #6092
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    whats the reasoning behind reversing the intercooling piping???
    Must admit never heard of it.
    Shortens the intake length a little bit so it will spool up faster, also cooled air comes out of the cooler and straight into the throttle body. Where as before if comes out of the cooler and thru a metal pipe to the TB... Causing some heat soak to the cooled air.
    2003 GU SIII Auto Grenade. All the goodies.
  4. The Following User Says Thank You to Softy For This Useful Post:
  5. #6093
    Quote Originally Posted by Softy View Post
    Like I said never heard of anyone doing it since Ive been here.
    I have a needle valve and TBH mine spools very quickly if I
    need it to
    @ Clunk might be a bit of black texta making it look "wonky"
    Im not 100% happy with it, but its ok. Now only one more for
    the other side for the reverse camera. Then Ill get the laser
    cutter onto the centre console knock outs.
  6. #6094
    May 2011
    Radelaide
    5 Post(s)
    Every little bit helps.. people reporting around 40-50c drop in EGT's also.. I'm yet to do it.... Been lazy.
  7. The Following User Says Thank You to Softy For This Useful Post:
  8. #6095
    Thats a good gain to be had,,,, Ill have to look into it LOL
    Ive wrapped one of mine in gold thermal tape. I also have a 76 mm intake
    Ive yet to fit as well
  9. #6096
    476 Post(s)
    Started replacing the body mounts. The rears and the 4th row ones are proving to be a pain in the anoos.
  10. #6097
    476 Post(s)
    Lol. Done. Except for the rears.
    I was jacking the body that much i had to have the rear doors open. So i just spaced the rear mounts and replaced all the others.
  11. #6098
    83 Post(s)
    Have you undone the radiator mounts so the body doesn't flex the cores as you are jacking the body?
  12. #6099
    476 Post(s)
    No i didnt. The radiator is only secured from the top and these mounts are designed to flex so i think these might be fine. Anyway we'll see tomorrow if the radiator is fine or not.
    I used a length of 100x100 of pine running between the 3rd and 4th row mounts and jacked up the entire side of the car from there. This worked really well, except for the rear mount. I just couldn't get the body up high enough. I just have to put the front seats back in and im done.
  13. #6100
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Finally got around to fitting my external speaker for my UHF so I can hear it over the rattling of my GQ on corrugations.
    One of those little jobs I've been too slack to get around to, oh well, done now 😀
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
