Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 48
Thread: EGR blocked today...
    Feb 2015
    Dartmoor, England
    One of the best & easiest mods Steve,
    Next, I would remove your manifold for a check and possible clean-out.
    Here's mine before and after..
    A small adjustment of your VGT screw is normally required to compensate for blocking the EGR, but best done with at least a boost gauge fitted.
    There's loads of stuff on here about this....
  2. #12
    So I've noticed the boost coming on stronger earlier and a can actually hear it spooling up now..
    But that's all feel.. no gauges yet to actually confirm..
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by steve4377 View Post
    ROFL 3Dogs...I remember that old one. Best axe he ever had. Only had three new heads and three new handles. Big chuckles...
    Cheers mate...
    Have you guys noticed the new heads and handles are not as good as the old ones.
  4. #14
    Onslow WA
    What...the new heads are Craft Handed In Northern Australia. Or as I prefer to call it...Made in CHINA...hehehehe
    Yeah will get around to that Daveyboy. Bit warm here at the moment though. I just measured the Tarmac temperature at Onslow Airport (on the ground not in the air) at 60 degrees Celsius. It was a 46 Celsius day but it melts boots. Don't feel like doing mechanical work in those temps!
    Cheers guys
    2004 Auto ZD30 wagon - pretty much standard...Just plodding along nicely!
  5. #15
    Feb 2015
    Dartmoor, England
    Damn that's hot Steve!
    We are due some snow here soon, but gone back to mild, wet and windy for now!
    I couldn't believe the coke I chiselled out of my manifold and she is definitely sounding better for it.
  6. #16
    Jun 2013
    Central West NSW
    Three dogs, no EGT gauges or Dawes fitted. Don't want them. Happy with the ecu boost control. If I have to watch an EGT gauge I don't want to drive the thing. Only interested in stopping oil mist into the manifold and stopping carbon soot in the manifold. I'm happy with that. The unit is 2004 and running great and hopefully will for a few years, but the body and interior is aging too, so if it blows the motor It'll just about be selling time. Starting to look her age exterior wise too, but I love driving the old troll and intend to keep here for a few years yet. The whole unit has been bullet proof for ten years, I'm happy with that. Time marches on for us all man and machine I suppose...
    Steve
    I blocked my EGR without Dawes and needle valve. No can do as I found. When EGR opens the ECU winds back the boost to allow the EGR to flow in, which now it can't as it is blocked, your EGTs now climb rapidly as you only have a couple of pound boost. Normally the EGR must come in under pressure, which I guess it is and make up the shortfall in boost, as before blocking you didn't notice boost drop at all.
    I would highly recommend some gauges, not necessarily for daily driving then but more so for when performing mods like these you can see the effect. I bought digital gauges, although not cheap, for the fact that they will alarm at presets when something is wrong.
    I have blocked EGR but don't have a catch can. From reading it sounds like it is the combination of EGR and oil mist that creates the sludge, so I often wonder that maybe I could have put a catch can on and not blocked the EGR would have got the same result?
    Lemo.
    http://www.nissanpatrol.com.au/forums/image.php?type=sigpic&userid=16293&dateline=137569  2513
    2006 GU IV ST 3.0L TD Di
    Autron Boost and EGT, Dual Bat, Dawes & Needle Valves, ARB Alloy rack, more to come.
  7. The Following User Says Thank You to Lemo79 For This Useful Post:
    Rock Trol (21st February 2016)
  8. #17
    After you fit gauges will you be fitting a Dawes and needle vavle?
    suppose it depends on what the gauges say eh
  9. #18
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    As Lemo79 said, you will need to take boost control away from the ECU now that the ERG is blocked. Otherwise you will be running low boost when you least want it.
  10. #19
    Onslow WA
    Lemo and Rock Trol you make very valid points. I just went for another run and I believe it perceptible that I have lost boost and had to put the loud pedal further down to the floor as a result of the lower boost. Think I will just remove the blocker. I've already fitted the catch can, so think I'll remove the blocker and leave it at that.
    Cheers for some sage advice.
    Steve
  11. #20
    Gold Coast
    My 2006 ZD30 had a conniption at 70k--dreaded water leak. When the engine was out we inspected the intake manifold--plenty of crud there even with Provent and low k's.
    I now have all the gear-Dawes, EGT, Boost etc. and have the EGR at optimum--if you get my meaning.
    There is a product that is sprayed into a vacuum hose to loosen all that stuff--it comes out the exhaust as you rev the motor. Not my liking to put that through the engine.
    That should give you a clue how much is blocking manifolds etc and you can make an informed decision on your plate.
