Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Knock in front end when turning left or right.
  1. #21
    476 Post(s)
    The 1st row body mounts are about 40mm in height new, 2nd row body mounts are about 45mm in height new, the 3rd and 4th row mounts are about 48mm in height new. Check this against yours.
    Wetty (25th February 2016)
  3. #22
    Apr 2011
    Check that the lhf panhard rod nut is done up super tight. I had a similar clunk which went away after loosening and retightening the panhard nut.
  4. The Following User Says Thank You to fenda benda For This Useful Post:
  5. #23
    Really would GU body mounts be flogged out already
    Long time between posts Fenda lol
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #24
    476 Post(s)
    Depends on how much off roading its done.
  9. #25
    Apr 2013
    Have same issue ATM turning sharp there's a front ene clunk only once, have just replaced panhard bushes and only really noticed it sence then and have already done radius arms and all other bushes but maybe due to using all nolathane there all flogging out on me will have a look when I get home thanks
  10. #26
    Jul 2015
    Camden NSW
    6 Post(s)
    Probably not related ..... but.
    When I recently fitted an adjustable drag link to my 2014 Y61 I noticed a knock when turning full lock right. Turned out that I had the drag link "back to front". If you mount them with the adjustment nut/bolt facing rear and not forward, they hit the diff on full lock right. Lesson learned.
