Results 1 to 10 of 12
Thread: tow bar, front, bull bar, GQ
    Feb 2011
    Brisvegas
    Since I am removing the factory alloy bull bar from my Mav to fit recovery points, I have decided to 'move forward' as our red headed PM says, on a front mounted tow bar to assist in parking the tinnny in the garage.
    Anyone done this already, or got some ideas?
    I am thinking about getting one of those flat tongue removable Magna type towbars and just bolting the receiver under the alloy bar, as the tinny isn't that heavy. I used to be able to push it up the drive myself until I upgraded the trailer :-)
    Retired boilermaker over the road wants to run some square hollow section between the dumb irons (pointy end of chassis) with plates bolting up under the new recovery plates.
    All ideas very welcome
    Most of the ones I have seen people either...
    Lazy option - drilled and bolted a tow ball onto the Bullbar
    Sexy option - cut and weld a Reciever in there (like your Boiler mate suggests)
    Certainly makes reversing up tricky driveways easier
  3. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    schon55 (27th April 2011), Silver (14th April 2011)
    Jul 2010
    Waterford West Qld
    Yeah I agree with boiler maker, if he does it right, you would be able to use it as a recovery point as well.
    Tim
  5. The Following User Says Thank You to Finly Owner For This Useful Post:
    Silver (15th April 2011)
    Feb 2011
    Brisvegas
    I found some RHS of more or less the right dimensions for the receiver for my flat towbar tongue at Bits of Steel in Geebung.
    The obliging bloke there literally shed blood to help out. He cut a slice of each side of my towbar tongue so it would fit neatly in the RHS with a tiny bit of slack. Lovely job on a big bandsaw (looked like they had an even bigger one there). A bit of a rough edge sliced through his glove and thumb. Not too much claret but I could see it smarted a bit. I've never been there before - have been to Eagle and Globe (probably now Bluescope I guess) in the past, but this one is closer.
    As I'm only moving my little 4.3 tinny, I'll be welding a plate across the RHS with provision to bolt it to the bottom of my alloy bullbar, with some bracing going up the back of the bullbar to be bolted onto the front face with nice smooth cup head gal bolts. well, that's the plan at this stage - adequate for the task and nothing protruding forward of the bar when not in use.
    I have installed my shiny new recovery points - my much loved factory hook is gone, replaced with a shiny red plate for each chassis rail, and since I saw some with a WLL rating, I have fitted a 4.5 tonne hook to each plate. I had to get longer bolts for the driver's side as the factory ones were just level with the top of the captive nut, and apparently best practice is at least one thread clear. They are 14 mm fine thread metric 8.8 grade. The left hand side has 16mm grade 8.8 metric, as they fit in the holes in the plate and chassis, with nuts to suit on a backing plate made from the old factory hook.
    Speaking of bolts, the factory mav alloy bar is mounted on two T shaped steel brackets. Each bracket is drilled and tapped for three bolts where they mount inside the chassis, but it looks like for a very long time, there have only been two bolts on each. So I now have a couple more bolts to suit :-)
    Legendary timbar's Avatar
    Feb 2011
    perth
    sounds good show us some pics ?
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
    Feb 2011
    Brisvegas
    normally getting pics onto the computer raises my blood pressure, esp via blue tooth, but I have learned how to do it :-) I have yet to learn how to shrink same.
    Almost as bad as dealing with Itunes.
    Need our kid to be a bit older so she can do it for me :-)
    I have a front mounted tow bar with the tounge that came with Bluey and bolts into the chassis when I bought the car.
    The guy used it to park his boat in a tight spot next to his house.
    I had to take it off for the RWC and I will never use it so if your down in Melbourne It's all yours for a slab of the finest ale...lol
  10. #8
    Feb 2011
    Brisvegas
    Could be!! I have a mate who lives somewhere in those self same Christmas Hills. The problem of course would be getting it here :-)
  11. #9
    May 2011
    Quote Originally Posted by Silver View Post
    Since I am removing the factory alloy bull bar from my Mav to fit recovery points, I have decided to 'move forward' as our red headed PM says, on a front mounted tow bars to assist in parking the tinnny in the garage.
    im here to ask for your help. i am thinking to buy a new tow bars and bull bars and install it. but i have no idea on how to do that. can you help me on this? thanks a lot.
    _____________________
    Current Inventory
    -2010 2LT/RS Delivered 10/10/09
    -2009 Malibu 2LT
    -2008 Nissan Patrol - tow bars
    -2007 Suburban 3LT
    -2007 Haulmark Enclosed Car hauler
    -2001 Pewter Z/28
    -2000 NBM Camaro
  12. #10
    Feb 2011
    Brisvegas
    Quote Originally Posted by ishie View Post
    Current Inventory
    -2009 Malibu 2LT
    -2007 Suburban 3LT
    -2001 Pewter Z/28
    -2000 NBM Camaro
    what model Patrol, ishie?
    If it has airbags then I think you need to get an airbag compliant bullbar. You may need to check the law where you are and see if it also has to be fitted by a licensed fitter?
    Are you looking to fit a winch? If so, talk to the bull bar manufacturer as to which of their models fits your prefered winch.
    As to rear tow bars, I guess these days we are restricted to new or second hand to stay legal - haven't checked this as I don't have the skills to make one anyway. If you are going to use the tow bar as a recovery point I'd go for the one that has a square female pipe that takes a tow hitch retained by a big cross pin - generically known by one manufacturer's name as Hayman Reece type or Receiver Hitches.
    "As a boat owner and a four wheel drive owner I feel like a pelican: every where I look I see a big bill in front of me”
