Page 125 of 187 FirstFirst ... 123124125126127 ... LastLast
Results 1,241 to 1,250 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1241
    476 Post(s)
    Or just get a can of anti splatter spray. Works a treat with mig and arc.
    MudRunnerTD (14th February 2016)
  3. #1242
    Keen to see the finished product though Dazz, will be a huge winner!
  4. The Following User Says Thank You to AB For This Useful Post:
  5. #1243
    yeah i have a can in the shed, i should have grabbed it out.
    Both sides are bolted up with minimal bolts ready to start the scrubs. Next weekend maybe.
  6. #1244
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Mig will still have a heap of spatter. Not quite as bad as flux core but plenty. If you want spatter free you will need to tig it
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  7. #1245
    How much did you take out of the body lift??
    If your getting lots of spatter you need to spend a little more time on the setup. You wont get it spatter free but you can certainly have very minimal spatter when the welder is setup accordingly.
  9. The Following User Says Thank You to nissannewby For This Useful Post:
  10. #1247
    yeah my welder is a very basic model with 2 switches ( 1 - 2, hi - lo) and line speed. It is also only 140amps and i was welding 4mm plate so basically had it on High and line speed 8/10. I think if i slow the line speed down and slow the welding down, its already slow it may well reduce the splatter. I am satisfied that i got good penetration though which is the main thing at this stage
  11. #1248
    Today was body lift reduction day.
    Kallen made a set of 20mm body blocks about 12months ago for me and I have finally got around to fitting them. I had to buy a new set of bolts as mine were all to long.
    I took about 30mm or so mate
    BigRAWesty (14th February 2016)
  13. #1249
    476 Post(s)
    Yeah nothing an angle grinder cant fix. Lol.
  14. #1250
    I remember now.. was just wondering if you could close the gap a bit by lowering the pipe down the plate a bit and then place a gusset above it to add more strength..
    Also remember you want to pull a Flux core mig.. same as the stick..
    When there is slag, you'd wanna drag..
    Normal gas mig you push..
    But also gas less you'll need to run hot.. if your worried about it dropping threw back off the heat and wire..
    With that sorta gap full peno will not be an issue lol..
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
