Results 1 to 10 of 20
Thread: Auto hubs locking in when in 2 wheel drive
    Apr 2011
    have been having trouble with front hubs locking in on the open road. they are the original hubs. travelled 260,000km should I replace with free wheeling hubs or genuine parts. Is there another solution to the problem.
    Legendary timbar's Avatar
    Feb 2011
    perth
    after 4x4ing do you reverse up to release the hub?
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
  3. The Following 2 Users Say Thank You to timbar For This Useful Post:
    Nobby (14th April 2011), schon55 (27th April 2011)
    Apr 2011
    Yes I make sure the light on the dash goes out before taking off. I had the front wheels jacked up off the ground and the hubs would click in by turning wheels. right hand side was worse than the left.
    changed the oil in the front diff because it was a bit milky (thought it could be water). had been driving in water as we had a very wet summer.
    other oils seemed ok.
    Did you use the correct Nissan Spec Diff Oil ?
    If the Diff Oil is the wrong spec that will also cause uncommanded engagement of the Auto Hubs
  6. The Following User Says Thank You to the evil twin For This Useful Post:
    Sep 2010
    Have you repacked them with grease lately? Too much grease can be just as big a problem as not enough with the auto hubs. If there is too much in there, it will pressurise and they won't fully disengage. Worth stripping them down, give them a good clean and put a thin coating of grease on all parts and reassemble.
  8. The Following 2 Users Say Thank You to XLR8 For This Useful Post:
  9. #6
    Check this thread for more info on auto hubs; http://www.nissanpatrol.com.au/forum...xing+auto+hubs
    Tony
  10. The Following User Says Thank You to YNOT For This Useful Post:
  11. #7
    Apr 2011
    will check the oil specs. do you Know what they should be for the front Diff? I know that it holds about 5.5L
  12. #8
    Apr 2011
    Had mechanic repack front bearings maybe that could be problem. But that was a few K's ago now.
    Thought it would have showed up earlier
  13. #9
    Apr 2011
    that seems like a good alternative to purchasing new auto or manual hubs. thanks 4 the tip. great thread.
  14. #10
    Quote Originally Posted by Nobby View Post
    Just a quick forum tip for you Nobby, when you're replying to multiple posts as you did above, click on "reply with quote" (like I did here) so people can see which post you are replying to, your replies will make more sense that way.
    Tony
  15. The Following 2 Users Say Thank You to YNOT For This Useful Post:
