Page 9 of 74 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 734
Thread: Jay see 1997 GU build up
  1. #81
    Quote Originally Posted by Kimbo63 View Post
    There will be no problem fitting a tee I done it for my oil pressure gauge as well go check your local hosemasters,pertek or Enzed
    Cheers mate.
    Will do.
  2. #82
    I've done the drive around and no one stocks a 12x1.25 tee. Hard enough to find anything that's 1.25, so I'm going to tap in a new one here.
    Has anyone got a 1/8 npt tap that I could borrow?
  3. #83
    My gauge should arrive next week, after a mix up on there end. Ive run wires though the firewall and up and under the dash.
    Where is the best place to get the +&- for the gauge and what about the light.
    Had a search for someone else's install but couldn't find one.
  4. #84
    http://www.ebay.com.au/itm/121258984...%3AMEBIDX%3AIT
    Is something like this helpfull ???
  5. #85
    Yes, but not for the temp gauge.
    Any threads showing how to install.
  6. #86
    Aug 2014
    Perth
    10 Post(s)
    check these out jay see http://www.ebay.com.au/itm/5-X-ADD-A...YAAOSwa39Uyve7 credit to ET, its what I used to get +ve for my EGT gauge, I had an existing -ve wire connected to one of the bolts behind the centre part of the dash. You can also get those adapters from Repco and SCA however you'll pay a fortune for one.
  7. The Following User Says Thank You to gubigfish For This Useful Post:
    jay see (31st January 2016)
  8. #87
    Wanting to lose the plugs for the dash cam and the GPS. Is there any problems to cut the plugs off and wire them into the accessories somewhere. Don't think it would be a issue, but want to make sure.
  9. The Following User Says Thank You to jay see For This Useful Post:
    lucus30 (6th February 2016)
  10. #88
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    If they are just 12v power no problem at all.
    Lucus30's 1999 GU ST TB45E
  11. The Following User Says Thank You to lucus30 For This Useful Post:
    jay see (6th February 2016)
  12. #89
    Thanks mate. I thought it would be fine.
    Now to do something about it.
  13. #90
    Another stupid question.
    The fuse in the plug is 1amp. The smallest under the dash is 5 amp, do I just disregard it?
    Like I've said in the past and continue to prove in the future, I not electronically minded.
