Results 1 to 10 of 11
Thread: Cheap IR thermometer
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I was thinking about a couple of recent threads where there were questions about whether the temperature showing on a gauge was correct.
    I'd always wanted one of these IR thermometers so I had a quick look on Ebay and saw one for $16.99.
    Has to be rubbish at that price, right?
    Well, I've tested it several times on my engine both hot and cold including the outside temp sensor and it's been within 0.5 degree each time.
    I've checked it against the TI outside temp display up in the roof console and my Ecutalk engine temp display.
    Came back from shopping with engine temp showing 81C so opened the bonnet and got 82C off the top rad hose after stopping the engine.
    John
  2. The Following User Says Thank You to jff45 For This Useful Post:
    mudnut (13th January 2016)
    Yeah I bought a cheapy off Ebay as well for the pizza oven and was suprised how good they are.
    177 Post(s)
    Sorry , very naive with these things. So you just point it at desired spot from a certain distance and gives you the surface temperature? ?
    So if I pointed one at my thernostat housing or sensor location I'd more or less get the same reading as the sensor ?
    Providing it's accurate of course.
    Tapatalked from S6
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Tapatalked from S6
    Yeh mate, what ever it pointed at is what it reads, and they are pretty accurate. I use one but way smaller about the size of a match box for my reptile cage temps. But I know a few that use the same sort in the op
  6. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    Hodge (13th January 2016)
    Morayfield, QLD
    13 Post(s)
    Yep, there's even a laser beam you can switch on to make the aim more precise. I used it this afternoon and aimed the laser spot on the outside temp sensor. Got almost 34 (has 1 decimal place) and patrol readout in console showed 34.
    John
  8. The Following User Says Thank You to jff45 For This Useful Post:
  9. #6
    Aug 2010
    17 Post(s)
    That's the downside 2 my small one no laser, but don't really need it for what I mainly use it for
  10. #7
    Mine sits in the Drivers Door compartment with my tyre pressure gauge and winch remote etc.
    When towing my Van on holidays, every time I stop for fuel I check the wheel bearing and tyre temperatures on the vehicle and Van.
    Adds bugger all time to my 'walkaround' before I fire up and piss off on the next leg
  11. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    jff45 (13th January 2016), Sprock (13th January 2016)
  12. #8
    Morayfield, QLD
    13 Post(s)
    Good idea!
    John
  13. The Following User Says Thank You to jff45 For This Useful Post:
    the evil twin (13th January 2016)
  14. #9
    Been singing their praises for a while now, great bit of kit
  15. #10
    Good idea!
    Yep... even if I do say so myself.
    It meant that I very quickly picked up an issue on the Van 'lekky brakes when one drum was way cooler than the other.
    I might add that I check the shockie temps after looong stints on corrugations as well
  16. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (13th January 2016), jff45 (14th January 2016)
