Results 11 to 20 of 23
Thread: Diff Breather
    dont forget gearbox/auto and transfer case as well
  2. #12
    Advanced Finezy's Avatar
    Geelong - VIC
    3 Post(s)
    they are all good, it has the stock metal lines running up into the passenger side guard behind the snorkle
    2001 GU II ST, 3.0di, Auto, All NADS done, Nissan Snorkel, 50mm Lift, 35's....
  3. #13
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Diff Breather
    I ran my diff breathers along the chassis rail up to the engine bay fire wall...., gearbox / transfer case are still on the todo list
    As others have said the rear diff factory breather is useless and terminates in the chassis cross member. Whilst The front diff and gearbox / transfer case go into he passenger side guard (3 metal tubes) - depending on your type of driving / depth of river crossings they recommend to relocate to the firewall as well
  4. The Following 2 Users Say Thank You to Bacho86 For This Useful Post:
    dom14 (13th January 2016), Finezy (13th January 2016)
  5. #14
    334 Post(s)
    Des Munday will sell the air line and fittings you need to make up a kit much Cheaper than an eBay kit.
  6. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
  7. #15
    Legendary dom14's Avatar
    38 Post(s)
    Thanx for that information mate. It's been very useful.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  8. #16
    84 Post(s)
    I went a cheaper option and also mounted the filters facing down so that no moisture can dribble down the tubes. I have lost a little bit of hieght, but if my rb30 has water that high, it isn't gunna run anyway
  9. The Following User Says Thank You to mudnut For This Useful Post:
    BigRAWesty (14th January 2016)
  10. #17
    Jul 2014
    6 Post(s)
    I did similar to mudnut, rubber hose with small fuel filters on the end. Did a loop with the end of my hose, not enough to crimp it, but thinking if I am ever deep enough, hopefully create a bit of an 'air lock' in the hose itself. Time will tell, but so far so good.
  11. The Following User Says Thank You to Throbbinhood For This Useful Post:
    mudnut (14th January 2016)
  12. #18
    What hose did you use?
    84 Post(s)
    Just an automotive grade rubber. I am thinking of upgrading the rear diff to chassis piece with some tougher stuff.
  14. The Following User Says Thank You to mudnut For This Useful Post:
  15. #20
    Mar 2011
    14 Post(s)
    I recall reading somewhere that you'll need to make sure it's oil resistant type hose, otherwise down the track the hose may break down
  16. The Following 2 Users Say Thank You to Bacho86 For This Useful Post:
    BigRAWesty (14th January 2016), mudnut (14th January 2016)
