Page 41 of 46 FirstFirst ... 3940414243 ... LastLast
Results 401 to 410 of 456
Thread: Rockets Wagon
  1. #401
    Your steering query.
    Your castor wont help but you are getting a few small things happening that makes it feel that way.
    You will be getting a small amount of rear steer. This is normal for a patrols rear suspension geometry. Your castor as you have said wont be helping. Also as your front left hand corner rises your steering arm will slightly alter in its position. So all very minor things that equate to what your feeling. You have a good chunk of torque now so you will be getting quite a bit of movement under hard acceleration.
    I know your rear end is in good nic since you have just fitted all that new superior gear.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    Rocket55 (2nd January 2016)
  3. #402
    Patrol Guru Rocket55's Avatar
    Sydney
    Haha, it's on here too.
    http://www.nissanpatrol.com.au/forum...h-the-throttle
    That's what I believe is happening also, seems to have got worse after the Superior engine mount went in on the passenger side, which magnifies the chassis movement.
    Cheers Rod
    My Build 2005 TD42TI
  4. #403
    Thats about the only place I didnt look haha. I dont use the search function as you can tell :|
  5. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (2nd January 2016), Rocket55 (2nd January 2016)
  6. #404
    Sydney
    We loaded up and took off for a break today, the Patrol is full and the van is at least 3 Tonne so I was very interested to see how the temps go after the latest round of mods. Blasted up the hills at 80-90km/hr which last time saw me backing off as the factory gauge was hitting the very top of the normal range, this time, it didn'teven move. Super happy so far!!! Mods included new 3 core Rapid Cool radiator, UFI fan and fan hub some new coolant and the removal of the bonnet protector. Air temp is low 20's. Hopefully it continues like this.
    Cheers Rod
  7. The Following 3 Users Say Thank You to Rocket55 For This Useful Post:
    Bacho86 (3rd January 2016), growler2058 (3rd January 2016), Hodge (3rd January 2016)
  8. #405
    Feb 2011
    Shed
    45 Post(s)
    Bonnet protector? Is that the sound deadner or the plastic strip over the nose of the bonnet?
  9. #406
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Plastic strip over nose of bonnet to stop stone chips normally I believe
  10. The Following User Says Thank You to Bacho86 For This Useful Post:
    Rocket55 (4th January 2016)
  11. #407
    Feb 2011
    Shed
    45 Post(s)
    A bummer i was gunna get one of those! I got stone chips
  12. #408
    Quote Originally Posted by Rocket55 View Post
    Got sick of the standard radio, so decided to opt for something a little better. First brand name radio I've had in a car for many many years
    Install was pretty straight forward, just a bit time consuming stuffing around with the rear camera, but in the end it came up pretty good. I'll have a better play with it tomorrow and see how it goes, but so far so good.
    Hey mate. Quick Q regarding the install.
    How did you go plugging the into the standard loom. Did you get a plug and play loom or was it a direct plug in setup.?
    You can buy loom adaptors for this Kallen. Well for my older GU i could... I would assume its the same for the later U's.
  14. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (4th January 2016), Rocket55 (4th January 2016)
  15. #410
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    What ?! Does taking that off make them run cooler ??
    2002 GU wagon 3.0lt , auto , piranha dual batteries , 3" lift , chip , needle & Dawes valves - just gettin started
