Results 1 to 10 of 17
Thread: Anyone had issues with their Provent 200 catch can?
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    I took the Patrol to a turbo shop a couple of days back because I was leaking oil in the intake, pre-intercooler. This is the same outfit that replaced my turbo in September, so the turbo itself is under warranty. After inspection and disassembly, they were convinced that it was my catch can (Provent 200) leaking oil back into the intake.
    Their reasoning was that logically, the heavier oil falls to the bottom of the can and lighter air rises, thus giving the separation that you need, but the outlet (return) for the clean air is on the bottom of the can. After looking at the complete Provent product line, the 200 is the only catch can with this kind of setup - all of their others have inlet and outlet up high on the can.
    We also found 3 points on the intake where it wasn't completely sealed, so we fixed those as well, and they were convinced that the combination of dirty air, plus the bad setup on the Provent, were the culprits for the oil leaking into the intake. After doing some quick research on the internet, I found that other have had problems with it as well, but on different vehicles. We "fixed" the Provent - i.e. removed the blow-off valve near the outlet hose and swapped the inlet/outlet hoses.
    I was wondering if anyone here has had any problems with their Provent 200 leaking oil into the intake, or do these guys really just not know what they are talking about?
    Feb 2011
    Shed
    45 Post(s)
    I'll be getting a Provent 200 soon. I was under the impression they're the ducks nuts!
    Jul 2015
    Siberia
    I was too. That's why I bought one. It just seems a bit strange that the outlet for the clean air is on the bottom where it can remix with the oil again before recirculating into the intake.
    176 Post(s)
    Had one on my 3l crd , with very bad blow by and caught a lot of oil but never had the issue you're experiencing. Will be getting one for the 4.2 shortly.
    Tapatalked from S6
  5. The Following User Says Thank You to Hodge For This Useful Post:
    SiberianPatrol (2nd January 2016)
    Read a few threads here and you'll see ppl put coils of alloy or similar[steel wool] for the fumes[mist] to stick to.
    My catch can is an all alloy with the in/out next to each other on the top, never had a problem, ever
    Jul 2015
    Siberia
    That's what I was finding most places was that the in/out was on the top, regardless of the can. The Provent has the filter element for the mist to stick to, so we'll see how the new setup works for me.
    bit hard from here without seeing how it looks
    at least it should solve your oil leaking problem eh lol
    Is it not plumbed backwards?
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    You tube clip from western filters / man filter may explain
    https://m.youtube.com/watch?v=FrvciHy2wD8
  11. The Following 3 Users Say Thank You to Bacho86 For This Useful Post:
    BigRAWesty (2nd January 2016), LaughingBeagles (2nd January 2016), SiberianPatrol (2nd January 2016)
  12. #10
    Expert LaughingBeagles's Avatar
    Mar 2015
    Have installed a prove that about a month ago. So far, so good.
    Tap tap tap
    Looking for a 4WD Club in WA that caters solely for Patrol, Safari and Maverick owners? Click here to HERE to visit the Western Patrol Club. Click HERE for the Beagle Mobile Mods!
