Page 41 of 52 FirstFirst ... 3940414243 ... LastLast
Results 401 to 410 of 517
Thread: Blocking the EGR Valve
  1. #401
    Feb 2011
    Shed
    45 Post(s)
    Righto ill be back when i fark it up
  2. The Following User Says Thank You to growler2058 For This Useful Post:
    taslucas (30th December 2015)
  3. #402
    176 Post(s)
    Champion mate. Does it matter which side of the gasket the plate goes on? Engine side or pipe side?
    I don't think it maters. From memory i left my gasket out... Been a few years now since then.
    Feb 2011
    Shed
    45 Post(s)
    Ive got some sensor safe silicone so i might use a tiny smear of that.
    Wouldnt ya know it the only ring spanner thats gone walk a bout is me bloody 12mm!! Quick trip to sprints when it opens
  5. #404
    .......... TPC's Avatar
    63 Post(s)
    I put the gasket on the engine side but as Hodge said I don't think it would matter.
    I would think you would need a socket rather than a ring spanner.
  6. The Following 2 Users Say Thank You to TPC For This Useful Post:
    growler2058 (28th December 2015), Predo the swift (3rd April 2016)
  7. #405
    176 Post(s)
    Yeah socket with extension from memory. You will not have enough room for a spanner, otherwise you'll be there forever doing 1/100th of a turn at a time.
  8. The Following User Says Thank You to Hodge For This Useful Post:
  9. #406
    Feb 2011
    Shed
    45 Post(s)
    RightO my sprints wasn't open fork them, need a 12mm ringy to replace the lost one. So intercooler off and the bracket holding the fuel hoses to the egr thing
    But this MOFO snapped getting it out ?!$@
    Anyway EGR blanking plate in (cheers TD) and it still runs YAY
  10. The Following User Says Thank You to growler2058 For This Useful Post:
    Hodge (28th December 2015)
  11. #407
    176 Post(s)
    Well done. Your engine is thanking you as we speak. It can finally breathe some fresh smog-less air.
    Feb 2011
    Shed
    45 Post(s)
    Thought id effed up big time. Took her for a drive pop bdrdrdrdrdrddddrrrrrr. Didnt tighten one of the intercooler pipes up enough and popped it off
  13. The Following User Says Thank You to growler2058 For This Useful Post:
    BigRAWesty (29th December 2015)
  14. #409
    Sorry for the lack of updates. Lots has happened and didn't get a chance to work on my EGR idea to get clean air in instead and avoid the errors altogether.
    Been running the car with EGR blocked. Basically TL;DR is that blocking is the only decent solution. There isn't a solution around this.
    This is due to the fact that a lot of air is pushed out of the EGR valve. I removed the EGR system completely and made a T-junction to route the cooling now that the EGR cooling tube thing is taken out. So my initial plan to just loop the EGR valve into the air filter system before the intercooler wouldn't work.
    Usually the air pushed out of the EGR is met with pressures from the exhaust system and cancel itself out. But one thing that I noticed is the EGR is open quite often to the point of stupidity. When put putting around the block, you could hear the EGR valve open often and every time it did, a km would've been taken away from the engine. Even if you made a chamber that can expand and contract, it would be too complex and too many parts that could go wrong.
    Get a OBD-II diagnostics unit like scanguage and keep it handy. Also if you are up for it, take the EGR system out completely. Soo much more room to work on the intake side of the car. I can change the fuel filter without killing myself.
    Also my engine is noticeably better. It feels more alive and no more black smog.
    Edit: Added photos.
    http://imgur.com/FXd9eQO
    http://imgur.com/KK0L986
    http://imgur.com/LZyJe3q
    I will replacing the hose that is connected to the EGR plate with a cap soon.
  15. The Following User Says Thank You to togenshi For This Useful Post:
    growler2058 (29th December 2015)
  16. #410
    Feb 2011
    Shed
    45 Post(s)
    I haven't done my fuel filter yet. Was looking at it yesterday and it looked like a bastard to do!
