Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 98
Thread: Frankensteins GQ Resurection
  1. #81
    Advanced OLY's Avatar
    so time to bolt the cab down firm, new bolts of course and nice big washers. the rear two had done what they all do and split the nuts out of their captive housings and the factory hole isn't big enough to fit a decent sized washer through so i ran a hole saw through and made them the same size as the others in the floor, i'll just put a grommet in to cover them up and they will look like that's how they were meant to be
    pulled the roof lining out
    and the factory insulation, no sign of rust at all no wonder these things rust so often though there is bugger all paint under the roof lining, pretty much just thin primer.
    splashed the first coat of paint on, couple more coats on the roof and a few on the floor and I can start to put the insulation in.
    Run Your Fingers Over My Patrol, I'll Run My Patrol Over Your Fingers!!
  2. The Following User Says Thank You to OLY For This Useful Post:
    Rossco (21st December 2015)
  3. #82
    Awsome mate, it's coming along well. Looks like so much fun would love to do this to my GQ, maybe one day. . .
  4. The Following User Says Thank You to Rossco For This Useful Post:
    OLY (21st December 2015)
  5. #83
    Legendary happygu's Avatar
    You might as well spray some fish oil along the sides of the roof in behind the roofside support panels and the roof itself, as this is where any rust will start on the inside and eat its way out to the outside in the gutters.
  6. #84
    Quote Originally Posted by happygu View Post
    great minds think alike, that's the plan. i'll coat everywhere in fish oil that i can't paint and hopefully it will stay rust free
  7. #85
    Awesome job if only I had the time and space to be able to do this, well done
    Might want to think about putting some acoustic batts down inside the 1/4 panels
    makes a big differece
  8. The Following User Says Thank You to threedogs For This Useful Post:
    OLY (25th December 2015)
  9. #86
    so this turned up with a courier yesterday
    it's 12sq meters of butyl rubber (doing the firewall, roof, floor and doors), 8sq meters of dense foam underlay, (firewall and floor under carpet), and 4sq meters of thermal quilt insulation (for the roof under the roof lining)
    now i just need to finish painting the inside so i can start to lay it all down
  10. The Following User Says Thank You to OLY For This Useful Post:
    BigRAWesty (3rd February 2016)
  11. #87
    even though the picture doesn't show it the best, i scrubbed the floor with sugar soap and got all the crap off it, after it dries i'll wipe it over with prepsol ready for paint.
    drilled out the spot welds to a couple of unnecessary brackets
  12. #88
    82 Post(s)
    Excellent write up of a great build. I look forward to seeing more of it.
  13. #89
    thanks mate i'm just looking forward to it being finished
  14. #90
    How's this going mate?
