Page 41 of 101 FirstFirst ... 3940414243 ... LastLast
Results 401 to 410 of 1003
Thread: Hodge's new 4.2
  1. #401
    You saying you've lost your water tight seal lo
    Have you been able to solve the coupling depth.??l
    On the pic on post 394 Id cut that brass fitting in half that will give you 8-10mm
    Plus cut the bung as suggested and that'll solve the problem IMO
  2. #402
    176 Post(s)
    More goodies !!!
    Tapatalked from S6
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Hodge's new 4.2
    Geeze mate what's everyone going to get you for Christmas if you're getting everything now!! Lol
  4. #404
    forgot to tell you I have plenty of diff breather kits here , bummer
    a lot cheaper too Id think
    Are those yellow discs for the top of the coils???
  5. #405
    176 Post(s)
    Plenty of goodies from other people. This was a few of my own treats for my self! lol
    It's ok I don't pay full price for these anyway. And yeah they are for the front coils but go under them. 10mm spacers. I need a bit of front uplift so it doesn't road sniff as much.
  6. The Following User Says Thank You to Hodge For This Useful Post:
    Bacho86 (22nd December 2015)
  7. #406
    176 Post(s)
    How hard is it drop a spring enough to slide a spacer underneath without the spring compressor ? I just need enough to slide the spacer underneath...
    Had a quick look before and might be interesting getting enough without taking too many components out.
    Raise car from front diff and support on stands, undo the shocks top or bottom ??? Disconnect sway bars and pahard rod and slowly lower axle ??
    Legendary happygu's Avatar
    The fronts are the hardest, and the springs may need a little manual help to remove.
    I never use spring compressors, and that may make it easier, but I found that if I disconnected all the bits you mentioned, I could then let the axle end down as far as possible on its own, and if that wasnt quite enough, I put my hydraulic jack in between the chassis and axle, and then by extending the jack, force the axle down further, and the spring pops out quite easy.
    The other bonus with the OME spacers, is that they quieten down the springs when they twist a little under compression and extension and you dont get the usual Patrol boooiiing from the passenger corner . You will love them
    Mic
  9. The Following User Says Thank You to happygu For This Useful Post:
    Hodge (22nd December 2015)
  10. #408
    Undo shocks. Unbolt manifold for brake lines off diff. Place chassis on stands. Undo sway bar from diff. Remove wheels. Lower diff as far as required.
    Undo shocks at bottom easier to get at.
  11. The Following User Says Thank You to nissannewby For This Useful Post:
  12. #409
    176 Post(s)
    Thanks fellas !!!!
    I'll have a go tomorrow. Just need a bit more up front, especially after winch was fitted.
    Patrol Guru Rocket55's Avatar
    Sydney
    I cheated a bit last time, when you jack it up to put the stands under the chassis, jack it up by the axle and compress the front spring a bit, then just put your spring compressor on and nip them up. Put your stands under the chassis and then lower the axle, the sprig is now held at a slightly shorter length, might save dissconnecting a heap of stuff. Especially if you're on;y looking for a bit to slip a spacer in.
    Cheers Rod
    My Build 2005 TD42TI
  14. The Following 3 Users Say Thank You to Rocket55 For This Useful Post:
    Hodge (22nd December 2015), nissannewby (23rd December 2015), Stropp (23rd December 2015)
