Results 1 to 10 of 13
Thread: Serpentine belt ZD 30
    Nov 2014
    How do i put a Serpentine belt on a ZD 30
    Route the belt thru the A/C , Crank, Alt and Power Steering as best you can then back off the tensioner and slide the belt under the tensioner pully.
    A socket breaker bar is usually the best tool to 'unload' the tension so you can get the belt on.
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    Col.T (9th February 2016)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I use a ring spanner on the tensioner and then use a ratchet strap that fits its hook into the other end of the ring spanner. The opposite end of the strap is wrapped around the passenger wheel. That way I can open the tensioner, lay under the Patrol and then easily move the belt into position.
  5. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
    BigRAWesty (14th January 2016), Col.T (9th February 2016)
    Dwellingup, WA
    Use the nut in the center of the tension pully arm, not the nut that bolts it to the engine. It is a different size. Put tension on it and hold it for a few seconds and wait for the tensioner to 'give'. Its not an instant response.
    And, make sure the belt is aligned correctly on all pullies before you start the car. Best to go with gravity and set the ones at the top first.
    Are you ready for Christmas?
  7. The Following 2 Users Say Thank You to Oversize For This Useful Post:
  8. #5
    Expert Col.T's Avatar
    Nov 2010
    Seaview Dwns.S.A.
    G'day all,
    looks like I may be up for a new belt on mine fairly soon, (08 CRD).
    I thought you had to remove the radiator shroud with all the fritzing around that involves to get at it.
    Not so?????
    Also thought it was necessary to keep tension on the tensioner spanner/socket while doing the replacement, inferring a bit of danger if it slipped.
    Not so?????
    I've got a pit so access underneath isn't a prob.
    Cheers,
    Col.
  9. #6
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    Quote Originally Posted by P51 View Post
    Don't know.........................try posting up an introduction as that would have to be the rudest post I have seen here so far
  10. The Following User Says Thank You to Woof For This Useful Post:
    rusty_nail (9th February 2016)
  11. #7
    Dec 2015
    WA
    5 Post(s)
    From memory I did it with just the lower section removed from the shroud.
    I did remove the complete shroud when I replaced the radiator, it wasn't that hard to do, changing the belt when the radiator is out was easy.
  12. The Following User Says Thank You to GeeYou8 For This Useful Post:
    Col.T (28th February 2016)
  13. #8
    Quote Originally Posted by Tuppa View Post
    snip... that would have to be the rudest post I have seen here so far
    We can easily fix that for ya Fido... how much higher would you like us to raise the Bar?
    P.S. Dang it is hot
  14. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (9th February 2016)
  15. #9
    Are you sure about that?
  16. The Following User Says Thank You to Clunk For This Useful Post:
  17. #10
    477 Post(s)
    Quote Originally Posted by GeeYou8 View Post
    From my recollection it goes on the same way you take it off. Lol
  18. The Following User Says Thank You to mudski For This Useful Post:
    jay see (9th February 2016)
