Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 55
Thread: ecutalk for ipad
  1. #31
    177 Post(s)
    Its great to see we fork out good coin for gauges and yet we still don't trust them and buy something else to monitor with. Lol.
    Basically I want to compare the pair over a period so that I can then safely, say, yeah the redarc is accurate enough or is talking shit to me.
    But sounds like it may be a fair bit of work for Stropp to setup.
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    You shouldn't really accept that the factory sensor is what will be the most accurate. I had an issue with mine some time back and it was reading consistently too low.
    I replaced it and it more closely reflected the thermostat controlled temps.
    John
  3. The Following User Says Thank You to jff45 For This Useful Post:
    Hodge (18th December 2015)
  4. #33
    177 Post(s)
    Yeah i figured both won't be accurate to a degree but I guess between the two I can gauge roughly what the Temps are during different driving conditions and then monitor any changes from there on.
    Tapatalked from S6
    Yeah but say if the readings were pretty much the same I would take it as the factory sensor is good... If there were a difference, then I would investigate.
  7. #35
    You can always meet at Airport West and try my Ecu-Talk.
    same goes for you to Eric, Its obd11 but with less wire 14 I think
    I needed to know this for my chip as well
  8. #36
    If you dont trust your speedo and prefer GPS to track your speed ,
    maybe the OE temps are off too. My temp gauge shows just under half
    when the motor is at 95 degrees
  9. #37
    177 Post(s)
    Well we have well and truly sabotaged Stropps thread. My apologies. lol
    @ threedogs
    My 3L CRD, needle moved every so slightly from under half, to half, and sometime just over half. Numerically this was equivallent from 87 - 91C respectively.
    However, my 4.2 once up to running temps, gets to just under half and stays there no matter what ambient temps, how hard I push the car, whether air con is on or not ... It makes no difference, which to me anyway is slightly concerning. Now I don't tow, and do not intend on towing anything more than a 6x4 trailer to the tip, for any forseeable future, but still......
    I'd like to see whats happening numerically. Which is why I'd like to compare the pair and go from there.
  10. The Following User Says Thank You to Hodge For This Useful Post:
    Stropp (19th December 2015)
  11. #38
    OOI Ill see if I can use my phone plugged into my ecu-talk as a display only,,, for you Stropp
    There back on track sorta
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #39
    Morayfield, QLD
    I've never had an issue with my speedo but I can soon see if there's an issue because I have Ecutalk and GPS read outs to compare with.
    John
  14. #40
    Patrol God Stropp's Avatar
    38 Post(s)
    Nissan Patrol TD42Ti GU III/GU IV, 2003-2006 is supported by Nissan Consult which means its not ODII compliant, that scan tool will not work for you Stropp
    what about with obd to consult adapter $5 on ebay??????
