Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: ecutalk for ipad
  1. #21
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Moved this thread into the Mechanical, Auto Electrical, On-Board Diagnostics section of the forum
    Toddie
  2. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    Stropp (18th December 2015)
  3. #22
    Patrol God Stropp's Avatar
    37 Post(s)
    i just googled it and they are almost ready to release the ios version so i will wait as its being tested now by KLASLO.COM and they have a video on youtube.
  4. #23
    37 Post(s)
  5. #24
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    That looks like it's for OBD2. The TD42Ti isn't OBD2 compliant
    John
  6. #25
    Aug 2010
    17 Post(s)
    Nissan Patrol TD42Ti GU III/GU IV, 2003-2006 is supported by Nissan Consult which means its not ODII compliant, that scan tool will not work for you Stropp
  7. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  8. #26
    476 Post(s)
    so if i get the elm327 bt adapter i can monitor temps etc as that is all i want to do.
    Yeah this is all I want to do aswell. See what the water temp actually is. I know the Patrol has the OBDII plug but is OBDI, or something like that. Will this work?
  10. #27
    37 Post(s)
    Oh bugger, I just want to be able to check proper temps on my iPad ☹️
  11. #28
    177 Post(s)
    Quote Originally Posted by Rumcajs View Post
    Sorry mate, you can't use that Torque app, that would only work on OBD2 protocol which yours it ain't even though the plug used looks like it. If you still had your ZD30 CrD it would work. Also I just noted you boys run TD42. ECUTalk is useless on that if there is no ECM. It only works on TD42Ti with ECM basically series3 and 4 only (2003-2006) which seems like the ones you have but still ECM only performs support functions so I'm not sure what you are expecting.
    Anyway, Android (The Nissan DataScan II for Android is intended for newer Nissan cars equipped with 16 pin OBDII connecter and use Consult II protocol over K line DDL2 with Bluetooth adaptor that utilises the ELM327 chip for communication) or Windows (ECUTalk) only. Why would you buy that expensive ConsultBT adapter is beyond me when ELM327 BT adapter can be had for ~$10+
    Regards
    Thanks mate. I do have a 4.2TDi . Which ECUTalk reads and is consult compliant.
    ELM327 as far as I can see and understand is OBDII which won't work on mine, meaning the ELM327 isn't going to work either ? Therefore if I want BT, i have no choice. For now I think I will stick with USB ECUTalk plugged into my small Netbook.
    Basically the most important function I'd like to see is the Coolant temps that the factory sensor reads, so that I can compare to my second aftermarket gauge readings.
    476 Post(s)
    Its great to see we fork out good coin for gauges and yet we still don't trust them and buy something else to monitor with. Lol.
  13. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Bacho86 (8th January 2016), Hodge (18th December 2015)
  14. #30
    37 Post(s)
    That's what I want to do but on my iPad.
  15. The Following User Says Thank You to Stropp For This Useful Post:
