Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: ecutalk for ipad
    Patrol God Stropp's Avatar
    38 Post(s)
    What sort of head unit do you have Stropp?
    i have an ipad i want to hook it to but the stereo is a sony if thats what you mean.
  2. #12
    Quote Originally Posted by gubigfish View Post
    Where did you get that attachment to attach it to the windscreen?
    just scans/scrolled through all the mount available on ebay,
    I've since used double sided tape and taped it in front of the insrruments.
    Works well there IMO and out of the way
    Here you go
    http://www.ebay.com.au/itm/UNIVERSAL...if9yin91wF6AUQ
    gubigfish (18th December 2015)
  4. #13
    Aug 2014
    Perth
    10 Post(s)
    Can you PM me a photo of your current setup?
  5. #14
    Unafordable
    4 Post(s)
    I've got the ECUTalk to work on Linux laptop albeit only in virtual machine running Windows. ECUTalk is based on C# and Linux Mono package is suppose to take care of that but I haven't been able to get it working as it uses some obscure/obsolete MS only software calls.
    Other alternative is Android based device with Nissan Data Scan software and ELM327 BT OBD2 adapter, it basically does everything ECUTalk does.
    Regards
  6. The Following User Says Thank You to Rumcajs For This Useful Post:
    Stropp (18th December 2015)
  7. #15
    177 Post(s)
    I bought the cable - USB direct from ECUTalk. Intention is to just run it through one of my small netbooks...
    However, I have an Android head unit, meaning I could possibly run Torque app using this.....
    http://www.trackelectronics.com.au/
    Still early days, Just doing my research on whether this will work or not.
    Ive just used double sided pressure sensitive tape and stuck it in front of the speedo/ tacho.
  9. The Following User Says Thank You to threedogs For This Useful Post:
  10. #17
    38 Post(s)
    yes i have had someone show me that but i will need to use an android device, i would rather just use the ipad that i have as a removable setup in the car for maps etc.
  11. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    Hodge (18th December 2015), threedogs (18th December 2015)
  12. #18
    Unafordable
    4 Post(s)
    .....................Still early days, Just doing my research on whether this will work or not.
    Sorry mate, you can't use that Torque app, that would only work on OBD2 protocol which yours it ain't even though the plug used looks like it. If you still had your ZD30 CrD it would work. Also I just noted you boys run TD42. ECUTalk is useless on that if there is no ECM. It only works on TD42Ti with ECM basically series3 and 4 only (2003-2006) which seems like the ones you have but still ECM only performs support functions so I'm not sure what you are expecting.
    Anyway, Android (The Nissan DataScan II for Android is intended for newer Nissan cars equipped with 16 pin OBDII connecter and use Consult II protocol over K line DDL2 with Bluetooth adaptor that utilises the ELM327 chip for communication) or Windows (ECUTalk) only. Why would you buy that expensive ConsultBT adapter is beyond me when ELM327 BT adapter can be had for ~$10+
    Regards
  13. #19
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    @Hodge, if you'd like to PM me your email I can send you a copy of the EC.PDF which outlines what functions of the TD42Ti ECU can be read by Nissan Consult.
    Ecutalk should read the same functions and possibly OBD Scantech software should also be able to read them using the Ecutalk cable.
    John
  14. #20
    38 Post(s)
    Quote Originally Posted by Rumcajs View Post
    Regards
    so if i get the elm327 bt adapter i can monitor temps etc as that is all i want to do.
