Page 38 of 101 FirstFirst ... 3637383940 ... LastLast
Results 371 to 380 of 1003
Thread: Hodge's new 4.2
  1. #371
    177 Post(s)
    Just ordered ECU / USB / Consult cable thingie !
    Does that give you engine temps[water]?
  3. #373
    177 Post(s)
    Yes, and a few other things on a 4.2Tdi only.
    Im going to use one of these in the top hose for extra water temps
    Ill put the sender underneath so it in coolant all the time
    http://www.ebay.com.au/itm/SAAS-Genu...QAAOSwU~FWDzOF
  5. #375
    177 Post(s)
    Not a bad idea mate . So you literally cut the rad. hose and fit that in between ? Never seen that before, would have maybe been more favorable than what I'm doing.
    Those guys/eBay shop you linked, are on Allied drive, in Tulla. Been there before.
  6. The Following User Says Thank You to Hodge For This Useful Post:
    mudski (17th December 2015)
  7. #376
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    You should be able to read everything that the Nissan Consult readers can.
    There was a thread on the other forum where a guy connected a cheap Windows 8 tablet from Coles to an Ecutalk cable.
    He then all the info on gauges in front of him.
    That means water temp gauge, voltmeter, etc and a bunch of other stuff specific to TD42Ti.
    Personally, I prefer the Ecutalk readout with all the info on it. I use it for my TD42T engine temp, volts and TPS.
    You could throw your temp gauge away if you get that.
    John
  8. The Following User Says Thank You to jff45 For This Useful Post:
    Hodge (17th December 2015)
  9. #377
    477 Post(s)
    You read my mind John. I was wondering if i could use an Ecu talk. I should have kept mine...
  10. #378
    Aug 2014
    Perth
    10 Post(s)
    How can you tell if you have one of these motors? Is it specified on the firewall VIN plate?
  11. #379
    Patrol God Stropp's Avatar
    38 Post(s)
    Quote Originally Posted by gubigfish View Post
    Yeh mate that's what yours is 4.2 turbo diesel intercooled 😎
  12. The Following User Says Thank You to Stropp For This Useful Post:
    gubigfish (18th December 2015)
  13. #380
    177 Post(s)
    Just check if yours can take it as ecutalk site says Tdi only.
    Tapatalked from S6
