Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 73
Thread: GQ Fixing...
    Dec 2015
    That's not a picture of my car, but it shows where the conduit should be from the air filter (missing on my car too)
    It runs fine enough picking up air in the engine bay, but i'd like to put something in there anyway.
  2. #22
    84 Post(s)
    G'day and welcome to the forum. Have a look at this thread: http://www.nissanpatrol.com.au/forum...-Helpful-Hints
    there is a picture of an RB30 engine bay.
    The Rb30 carby has a heater grid at the base of the carby. I removed mine as it was already disintergrating and bits were getting chewed up by the engine. I got better performance and economy as a bonus. I had to reinstall the preheat flap to help with warming the engine up as I live way down south, but it may not be an issue for you.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    BigRAWesty (17th December 2015)
  4. #23
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    I'm wondering if someone has already tried this, and butchered it before he brought it...........
    hence the hard to start.........
  5. #24
    Here he is. Was waiting for you.
    How are you going for parts for yours MN
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
    mudnut (17th December 2015)
  7. #25
    Dec 2015
    Hey Mudnut, your thread was one of the first I read. I almost stole your pics to explain the situation.
    A few people have mentioned the carby heat grid, so I guess i'll check it out and see what the go is.
    I'm and heading further and further south, so I the preheat think might become more relevant for me.
  8. #26
    Dec 2015
    Update: Well the Carby is off (funny, they always say never work under a car only supported by a jack, but they never say never work under a bonnet supported only by rickety metal stick).
    It looks like someone already removed the little grid. Plus I found a sticker that said "Johnno was here" (or words to that effect)
    Anyway, while it's off I'll empty a can of carby cleaner into it. Tighten all the screws, and carry on.
    I've been reading through Dom14's carb rebuild from 2013, which was quite helpful (but more than I am interested in doing. I want to be back on the road this weekend!)
    Is it worth replacing these gaskets?
    RB30S CARB GASKET UPLOAD 2.pngRB30S CARB GASKET UPLOAD 3.pngRB30S CARB GASKET UPLOAD 1.png
  9. #27
    Patrol Guru
    Jul 2014
    6 Post(s)
    For your airbox/air ducting - I've just run flexi hose from the end of my airbox to my snorkel.. I use a good quality air filter on the main filter unit and got rid of the pre-filter, haven't had any issues thus far. Gave my airbox a wipe out before I hit dirt last time, and whilst I could see dust on the outside of the filter, the inside part was clean (on the airbox as well).
  10. #28
    Dec 2015
    That's pretty much what I'm thinking, once I get the steering back together, I'll head to the shop and get a bit of hose and clamps.
  11. #29
    84 Post(s)
    Going Ok thanks Kallen. As for parts, they are few and far between.
  12. The Following User Says Thank You to mudnut For This Useful Post:
  13. #30
    84 Post(s)
    Quote Originally Posted by RedRoadRunner View Post
    Retain the gaskets if they aren't brittle. I have slipped a small ball bearing into the pre-heat flap vacuum hose, for the warmer months.
    I will retain the dust collector when/if I ever get a snorkel. I am thinking of fitting a clear bowl with a tap so I can drain it and also clean out the dust regularly. Also keep the deflector can that juts down into the inlet manifold as it is there for a purpose.
