Page 32 of 46 FirstFirst ... 3031323334 ... LastLast
Results 311 to 320 of 456
Thread: Rockets Wagon
  1. #311
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I run Nulon longlife in a 50/50 mixture. Change every 2 years..
    Ran it for 8 years in my TB45 engine and now use the same in my TD42T.
    John
  2. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    BigRAWesty (19th December 2015), Rocket55 (15th December 2015)
  3. #312
    Hardcore
    central coast nsw
    Quote Originally Posted by Rocket55 View Post
    I've also had a bit of a girls look and could find any either, but by no means did I have an exhaustive look.
    Seeing as though I'm dumping the coolant anyway, I was thinking of just running a 1/4 BSPT I think they are tap through it, no drilling required. Others have done it in situ, grease up the end of the tap to catch the swarf and as the coolant runs out it washes any escaping deris out with it.
    Put the info & pics here.
    http://www.nissanpatrol.com.au/forum...l=1#post647940
    cheers.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  4. The Following User Says Thank You to Robo For This Useful Post:
    Hodge (15th December 2015)
  5. #313
    Aug 2014
    Perth
    10 Post(s)
    hey mate
    when you got your airbox from Fatz did you get them to supply the pipe work to the turbo as well or did you source from somewhere else?
  6. #314
    Quote Originally Posted by gubigfish View Post
    hey mate
    @ GF if its something like this I got the lot from ebay even the stainless elbows.
    pretty cheap too
    gubigfish (15th December 2015)
  8. #315
    Aug 2014
    Perth
    10 Post(s)
    do you remember what you searched on ebay?
  9. #316
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    hey mate
    I got mine through UFI. I'm not sure if they make them up or Fatz makes them up, but it fit like a glove.
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  10. The Following User Says Thank You to Rocket55 For This Useful Post:
  11. #317
    Ill grab a link to the stainless elbow the clamps search for T bolt clamps
    the other is just silicon hose, will put link here
    http://www.ebay.com.au/itm/76MM-3-OD...YAAOSwNSxU2bO~
    http://www.ebay.com.au/itm/3-0-inch-...4AAOxygj5SmDqo
    http://www.ebay.com.au/itm/3-0-Silic...YAAOSwQItT8cmB
    Or you can use silicon bends with small pieces of 76mm exhaust pipe to join
  12. #318
    North brissy
    How long is the proposed wait on your ufi gear this time?
  13. #319
    Sydney
    3 Post(s)
    Item was in stock and supposedly already on its way....
    Cheers Rod
  14. The Following User Says Thank You to Rocket55 For This Useful Post:
    rusty_nail (15th December 2015)
  15. #320
    Sydney
    3 Post(s)
    All this stuff turned up today.
    2 x genuine gearbox mounts
    1 x genuine engine mount (drivers side)
    1 x Superior engine mount (passenger side)
    Cheers Rod
  16. The Following 2 Users Say Thank You to Rocket55 For This Useful Post:
    Clunk (16th December 2015), Winnie (16th December 2015)
