Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Which diffs interchange?
    477 Post(s)
    Quote Originally Posted by Deevo View Post
    Thanks for that Mudski. My diffs are HG39 with 11 bolts so therefore I have H233 diffs with a 3.9:1 ratio. They are the original diffs (I've had the car since new). If I'm understanding you correctly, this means I can safely buy any 4.1 diff and expect it to bolt straight into the respective banjo (whether it be front or rear) providing it is NOT out of a ute. Correct? Thanks for your help -it's what I was after.
    You need to get one front and one rear. Not two of the same... as the rear has the LSD and the front doesn't. As far as I'm aware the fronts are the same from ute to wagon.
  2. #12
    Also the fronts are a 31 tooth spline axle and the rears are 33.. (note, that's in the gq.. I'll check my gu diffs once home)
    So you'll definitely need a front and rear set.. regardless of lsd or open. .
    477 Post(s)
    yep. Rear will be lsd and front not.
  4. #14
    Jan 2015
    Canberra
    Sorry to hijack the thread, but will an LSD rear fit in a front? If so, it seems like an easy way to get better front traction.
    WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
  5. #15
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Hi Deevo
    You can find the ratio stamped on the crown wheel might come in handy if buying s/hand diff
    Cheers kimbo
  6. #16
    Apr 2011
    Melton
    Depending on the model a rear lsd centre can be put in the front
    I have a rear H233b lsd from a mk wagon in the front of my gq as the both have the correct spline count on the axle. To retain the correct ratio, I swapped the ring gear from the gq front.
    You cannot put a lsd from the rear of a gq in the front of a gq different spline count. Also, it is a good idea to have manual uubs, to prevent wearing out the lsd on ashfelt
  7. The Following User Says Thank You to GQ TANK For This Useful Post:
    BigRAWesty (25th January 2016)
