Page 29 of 101 FirstFirst ... 2728293031 ... LastLast
Results 281 to 290 of 1003
Thread: Hodge's new 4.2
  1. #281
    177 Post(s)
    Haha cheers jff and the rest ... Parts,gauges,pillar pod ordered.
    Tapatalked from S6
    Hi Eric I noticed a few posts back you used an ockie strap to secure a drum of oil.
    Please throw it an any others in the rubbish and use ratchet straps, ockie straps are an
    accident waiting to happen, especially if you have yong children around, just saying lol
    mudski (8th December 2015)
  4. #283
    477 Post(s)
    I'd agree with you here. Ratchet straps are good and safe. I only use occys to hold the tarp down over my camper.
  5. #284
    wait till a mate loses an eye and you'll change your mind,
    I never use them and havent for over 20 years.
  6. The Following User Says Thank You to threedogs For This Useful Post:
    King_ady1 (8th December 2015)
  7. #285
    177 Post(s)
    I agree on the straps. I only use them inside on the cargo barrier. Very convenient.
    177 Post(s)
    Fitted up the rear work / flood / reverse light from LED Light Co.
    Wired up with a switching relay to work when reverse kicks in OR with a flick of a switch it'll work simply be a work light .
  9. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    Clunk (10th December 2015), Rocket55 (8th December 2015), threedogs (8th December 2015)
  10. #287
    Dec 2015
    VIC
    Have you got a dual battery set up? If so, how did you wire it? I'm guessing when it's activated by the reverse gear it will be powered by your main battery, but when it's switched on as a work light you would want it to be powered by the aux batt?
  11. #288
    177 Post(s)
    It is powered from the aux. battery , regardless whether I switch it on manually , or it is triggered by reverse gear.
    Tapatalked from S6
    177 Post(s)
    Here is how it's wired up.
  13. The Following User Says Thank You to Hodge For This Useful Post:
    DaveGQ (16th December 2015)
  14. #290
    177 Post(s)
    I'd like to do a cooling overhaul over the coming ages, as I cannot tell by records when the last time coolant was touched on this thing.
    Things like full drain and flush, new thermostat, fresh coolant, maybe even a new radiator ?? Just brainstorming at the moment.
    I spoke to a 4x4 shop today I will not name, but they were very hesitant to take on the job due to some bolt on the thermostat housing that goes a long way down into the block ?? Thats backfired on them a few times ?? Supposedly it commonly snaps off and front of the engine has to come off to get fixed ?
    Was this bloke onto something or just pulling my leg ??
    Cooling is detrimental to the 4.2 hence it's not a job I'd like to throw my amateur approach at. However it's made me even more cautious after what he told me.
    Thoughts ?
