Page 30 of 46 FirstFirst ... 2829303132 ... LastLast
Results 291 to 300 of 456
Thread: Rockets Wagon
  1. #291
    Patrol Guru Rocket55's Avatar
    Sydney
    Hi bigfish, the intercooler itself is a piece of cake to install. The bonnet bit can be a bit fiddley, although I must admit the second time I was pretty cautious as I really didn't want to cock it twice. Really it all went together pretty well and sealed up pretty good. You can adjust the cooler up a bit if you need to, I didn't bother. When setting the position of your scoop I set the back of the scoop 12mm from the back of the bonnet. This was based on some golden advice from Bob I think it was at Fairline who makes the scoops for Cross Country.
    Cheers Rod
    My Build 2005 TD42TI
  2. The Following User Says Thank You to Rocket55 For This Useful Post:
    gubigfish (5th December 2015)
  3. #292
    Sydney
    Little job for this evening, to replace my buggered steering damper. Out with the out Pedders POS and in with a nice little FOX Series 2 unit. Came up nice and made quite an improvement, tidying the front end feel up nicely. I imagine a set of these things all round would be pretty nice.
    Cheers Rod
  4. #293
    Hardcore
    central coast nsw
    Just read the last 10 pages or so,
    Its a good feeling when it all comes together, diy and it pays off.
    The support from this forum is awesome hay.
    yes, they sure make fantastic tow vehicles tickled a little.
    another happy chappy.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  5. The Following User Says Thank You to Robo For This Useful Post:
    Rocket55 (5th December 2015)
  6. #294
    Sydney
    Thanks Robbo. It's very satisfying to build it yourself and learn along the way. You're right there's some very good and smart people on here that are willing to give up time and expertise to help people out.
    Cheers Rod
  7. #295
    Sydney
    Painted my bonnet white again after my little mishap. Looks much better now.
    Cheers Rod
  8. The Following 5 Users Say Thank You to Rocket55 For This Useful Post:
    Clunk (10th December 2015), gubigfish (10th December 2015), Hodge (10th December 2015), LaughingBeagles (13th December 2015), Stropp (10th December 2015)
  9. #296
    Nice one Rocket, OOI do these scoops have vanes to direct air to the front of the Intercooler
    or is all the air forced to the rear.
  10. #297
    Sydney
    There's no veins in there John, it's just a hollow scoop.
    Cheers Rod
  11. #298
    Quote Originally Posted by Rocket55 View Post
    Leave it with me I have an idea on how to get air to the front,
    Im thinking it would make the IC more efficient too
  12. The Following User Says Thank You to threedogs For This Useful Post:
    Robo (11th December 2015)
  13. #299
    Hardcore
    central coast nsw
    Lately been thinking about this also,to make the most of my large cooler
    arc have a nice bit of kit but expensive and only fits their scoope.
    make a deflector with a right angle bracket at each end.
    mount it top the bonnet under your scoope.
    humm thinking thinking,
    it could hang down a little below bonnet line to help stop air flow sneaking under and behind it.
    some air bypassing under it could make a air curtain blocking directly behind it,
    only way to tell would be to try different designs with a temp gauge on ic exit, to see what works best.
  14. #300
    Patrol God Stropp's Avatar
    38 Post(s)
    Here is what we did with mine to try to direct the air, I think it works ok
  15. The Following 5 Users Say Thank You to Stropp For This Useful Post:
    BigRAWesty (11th December 2015), gubigfish (11th December 2015), MEGOMONSTER (11th December 2015), Robo (11th December 2015), Rocket55 (11th December 2015)
