Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Breather lines on 2014 GU
    Wollongong, NSW
    So I just wanted to get some clarification on the diff/gearbox/transfer breathers in the newer GUs.
    What I can see on mine is the breather lines come up from the various cases into the bottom of the engine bay (see below)
    The breather lines are the front 3. I believe the two behind are vacuum lines for the rear locker.
    From there they go into this plug in the left of the engine bay above the front left wheel arch. With the 2" lift in my vehicle that plug ends up just over 1m from the ground
    So what happens to them on the other side of there? Are they just open or are there filters or one-way valves attached?
    My friend is wanting to do a "river" crossing and I'd like to sort out any shortcoming in the breathers before then.
    ...and yes, I realise the rear diff needs attention due to it being much lower than the others.
    I ran new breather lines and they terminate on the firewall behind the motor
    I used 6mm push fittings
    Wollongong, NSW
    Yeah, that's what I was intending to do but I also wanted to double (and triple) check I was looking at the right hoses.
    Should I just disconnect the poly section from below the engine and run new stuff from the metal tubing? What do I do with the tubes still attached to the side of the engine bay? Just coil them up tie them out of the way?
    334 Post(s)
    Quote Originally Posted by terra_australis View Post
    Yes. Go to the last joint and extend from there will be fine mate.
  5. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    threedogs (21st November 2015)
    Wollongong, NSW
    OK, I'll have a play on the weekend. Thanks
    334 Post(s)
    Or cut the tube where ever it suits you and join from there mate. Your never going to remove the breathers so the factory will be obsolete.
  8. #7
    Advanced qwertytank's Avatar
    Jan 2015
    Galston, NSW
    Hi Terra
    How did you go with your breathers?
  9. #8
    Wollongong, NSW
    Just awaiting my kit. It's in the post. Hopefully gets here before the weekend.
  10. #9
    Jan 2015
    Galston, NSW
    Good luck with it. Do let us know how you get on, I'd be keen to see some photos if you have a chance to take a few.
  11. #10
    Wollongong, NSW
    Kit arrived today. It's the PU hose type with the push fittings.
    As soon as I looked at it I wondered how I was going to join that hard plastic tube to the existing lines.
    Any thoughts or do I improvise? I was thinking maybe using some barbed joiners for aquarium air hose... looks about the right dimensions.
