Results 1 to 5 of 5
Thread: Manual Transmission Gear Oil for a Newby
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Gearing up for all oil changes in my '99 GU RD28Ti in preparation for the cold
    Just read the manual and see that the gearbox oil calls for 80W-90 GL-4 gear oil. I just realize that I bought GL-5 gear oil. Is this a problem or can I use the GL-5 in the transmission or do I need to go back and try to find GL-4? What is the difference between the 2?
    Expert 92GQ's Avatar
    Sep 2013
    Qld
    Hi, I once put gl-5 in my gearbox and it made it very hard to change gears, apparently the gl-4 spec helps with the brass synchos in the patrol gearbox.
    I use penrite pro gear 75-85 gl-4 and it shifts perfect. Works well under load as well.
    http://www.penriteoil.com.au/product...d_products=375
    1992 TD42 GQ Patrol Wagon
    My GQ Build Page
    Jul 2015
    Siberia
    Thanks mate. Penrite isn't an option over here in Siberia. Can probably find Shell, or Mobile or Castrol here. Will have to take it back and swap for the GL-4
    Expert billyj's Avatar
    gordon
    castrol vmx-m
  5. The Following User Says Thank You to billyj For This Useful Post:
    SiberianPatrol (15th November 2015)
    As above. Make sure you stick to the gl-4 spec oil.
  7. The Following User Says Thank You to nissannewby For This Useful Post:
