Results 1 to 10 of 15
Thread: GQ trouble starting / bogs down on petrol ??
    Oct 2015
    hi guys i have a couple of very frustrating problems with my petrol/gas GQ. The first problem is it wont start on gas hot or cold, the previous owner said to change the plugs from bpr5es to bpr6es, because to start it on gas i needed hotter plugs, well ive changed the plugs to bpr6es, and it still wont start properly on gas. I think i may have seen a slight improvement starting on petrol but it hasnt fixed the gas start up atall. I went to see a mechanic who was recommend to me, hes had GQs most his life and so has his other mechanic so im pretty confident i have a good mechanic hes a great fella too, very helpful. He showed me, turning the ignition on 3-4 times before starting it will release more gas to start it, and this works probably 50% of the time, but if this doesnt work the first attempt then it wont atall i have to go on to petrol start it then flick to gas and run the petrol out. So common sense tells me (because im no good with engines ect) one ignition turn isnt releasing enough gas to start it right up, what do i need to do to fix this ?
    my second problem is when im on petrol, if i put my foot down and im climbing even a slight incline it will bog itself down try to come back but then it will just cut out in while driving, ive got a new fuel filter to replace it, but the filter isnt in its normal position so i have to find that too, it also has an electric fuel pump which ive been told could have some crap in there. Basically it feels like when i put my foot down on an incline its not giving itself enough petrol to keep up so it cuts out comes back abit maybe, then it will cut out.
    if anyone can help me with these problems it would be much appreciated.Iim getting real frustrated now
    what type of prime system does the gas have , some give a small squirt of gas when you turn the key.
    turning it on/off twice does this help? ok just read the lot.
    I think you need to give the system a birthday. put a kit through the converter, new air cleaner
    etc. 99% of gas problems are electrical. but you may be staving for gas does it back fire at all??
    It will bog down on fuel because the carbie is dry from lack of use and the accellerator pump in
    the carby is dry also
    Need more info mate...
    Is it Carby or EFI?
    Is it timed for gas or petty?
    How often is it run on Petty?
    Does it have an extended rotor button and/or hi-performance plug leads and/or have an aftermarket ignition etc?
    Does your system start on LPG if selected or does it use petty to start and switch to teh selected fuel when it runs?
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    what gap are you using on the spark plugs ? what gas system you running ? how many km on the engine?
    Oct 2015
    hi guys thanks for the replies, my GQ is carby, but im not sure what its timed for, it runs better on gas, but is faster on petrol, its only driven on petrol 2-4 times a week, which is only when i cant switch it from petrol to gas after starting it on petrol, this has happened a few times now, so il drive on petrol hoping it wont starve itself when my foots down either for a little but or if im on an incline, but its almost always does cut out eventually.
    Im not sure what an extended rotor button is but if you describe it i can have a look, it does have bosch leads on which the mechanic pointed out as an upgrade,and it does have and aftermarket electric ignition but im not sure which one/brand. It is suppose to start on LPG when selected, but wont ever start one first full turn it has to be prompted with 3-4 ignition turns first. Im sure it doesn't use petrol initially then switch to gas, but maybe this is a good option ?
    Im using 0.8mm ive followed the gap they were pretty much at, which was the same as the BPR5es that came out, and the mechanic said id would be good with what they were already set at. its never back fired.
    I have found something out today, after i put 40L of gas in it started every time right up after 3-4 ignition turns, and was pokie as on the road. last night o the way home it drove like s!@t, it was restricted in the revs and couldn't drive past 65-70, i dint thing i was out of gas because my trip said 300k and ive been getting around 400k, but after fueling up today obviously i was
  6. #6
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Bump for Baloo as his last post went into moderation
  7. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    baloo (17th November 2015)
  8. #7
    Go over the gas connections with some soapy water,
    can you smell gas at any time???
  9. #8
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    what Gas system is in your Patrol
    what year is your Patrol
    what Motor is in your Patrol
    these things will help people like ET, to help you diagnose what the problems are.
    as a "for instance" my old GQ with a TB42 - I had faster off line speed in petrol, but I could spin 11R tyres on a dry bitumen road..........
  10. #9
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    if you can take a picture of the engine bay
    and post it up
    some one may be able to recognize the system etc
    and give you some hints to look at
  11. #10
    Oct 2015
    i have smelt gas briefly before threedogs, but im sure it was just after i started it.
    im not sure what gas system is on it, but its a 1990 GQ 4.2 petrol/gas. Ye il have to take a picture, cheers
