Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
Thread: leaking big time
    leaking big time
    Went down to Richmond the other day to pick something up 25k city driving and the Patrol
    got warm on the way home. It has been losing about 1 ltr a month so thought nothing of it.
    Went to the Doctors [15k] and the same thing happened now Im getting worried,
    Drove over to the powder coaters today and it was very hot. Every other time
    Ive checked and never been able to find any water, untill this morning .
    Looks like Ive split the over flow bottle, cant see the split but under pressure it pours out.
    Under $100 for a newy, now to slowly drive to Airport west to pick it up.
    Hopefully that will be my water loss problem, could of been worse eh
    Much worse..
    Good to hear its a easy fix.
    Has anyone else split their over flow tank and was it hard to see the split??
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    My work involves maintanence to mobile plant and one recomendation I always make to my customers is to check the ground when they park up the plant. When next using the machinery, move it a machine length and check the ground where it was parked/stored for fluids,stains or even nuts and bolts that were not there when you parked it. Saved a few motors over the years where seals were leaking oil and the operator noticed the oil and shut down in time to save the engine. Iv'e told so many customers that now I am in the habit at looking at the ground where my car was parked every time I drive away.
  5. The Following 3 Users Say Thank You to 4bye4 For This Useful Post:
    BigRAWesty (11th November 2015), schanmala (13th November 2015), threedogs (10th November 2015)
    I never had water /coolant under the Patrol nor any wet spots until today when something has let go.
    Be it a split tank or hose, using a torch the best I could figure out was it was between the overflow tank and the Aux battery.
    I removed the tank but couldnt see anything, maybe the seam is split making it hard to see.
    And yes I always look under the Patrol or take notice of any oil spots before I park.
    Cant do anything tomorrow as I have a conference call I need to be at.
    so thursday Ill try and drive it to TJM Airport West and change the tank there and then.
    ... is that where the overflow tube from the overflow tank vents?
    (hope that makes sense)
    You might just have a dodgy overflow tank cap?
    Try filling the overflow to the max line...putting the cap on... and blowing some low (a couple of PSI) pressure compressed air down the line from the Rad
    Ive just brought new caps for the tank and for the radiator.
    Where does the hose go from the RHS of the tank ,LHS
    goes back to the radiator.
    will have a decent look at it tomorrow
    snip
    IIRC on mine it tucked down the back of the bottle and just ended...
  10. #9
    Ill change caps again an see what happens
  11. #10
    476 Post(s)
    Did you get a new tank? Like i said to you via text yesty, the split on mine was so fine i couldn't see it straight away, as the discoloration of the plastic made it hard too. But under a bright light and looking for ages i found it. If there is coolant sitting in between the two tanks it could well be the tank.
