Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 79
Thread: My new mate Seamus.
  1. #31
    177 Post(s)
    Yeah that middle photo shows the dawes valve. So it is boost limited. Nice.
  2. #32
    Expert King_ady1's Avatar
    Beveridge, Victoria
    Ash cool. That makes me happy. I was confused when everything was telling me I needed to tap a line in for boost gauge. I was looking at it like "what's wrong with that one???" Lol. All makes sense now
  3. #33
    Beveridge, Victoria
    So a quick update. Started adding a few little things on the big guy. 1446638913901.jpg
    Started out here,
    Made it to here,
    Had to cut a little off the end as it had some extra length. Lol
    Managed to get it all in and looking nice.
    Just left us wiring it all up. Only small hickup I found was the bung in the exhaust is different size to the sensor but. I'll drop by somewhere and see if I can get something for that tomorrow arvo.
  4. The Following 2 Users Say Thank You to King_ady1 For This Useful Post:
    2TROLLFAM (5th November 2015), BigRAWesty (4th November 2015)
  5. #34
    Beveridge, Victoria
    Other thing... As I didn't drive it to work today he sat in the driveway all day. So he Sat for about 24 hrs, came home to a bloody big puddle of coolant on the ground??????? Literally see it dripping... Looking under I can't see too much from the source, but does run a lot.. Main spots noticeable just under and behind the air con unit.... But the driveway does have quite a bit of a lean backwards.
    Also while looking for the leak found a random hose to nowhere....?? Not the reason for coolant, but is it Normal???
    Off to search the forum for any answers!!!!
    Btw, it's amazing how fast happiness can turn to fear 😨
  6. #35
    177 Post(s)
    That hose will be the air con drain hose ?? I'm guessing.
    Source of the leak could be anywhere mate. Did you maybe knock a hose clamp or something while tinkering under the hood last few days ??
    I hope it isn't the dreaded front timing cover coolant leak super common to the 3L variety. It's a rather expensive fix.
    Beveridge, Victoria
    I haven't played with any of the hoses. But could have bumped something... Can't see or feel any leaks from any hoses or connections.... I actually just came across your thread on this particular problem.
  8. #37
    177 Post(s)
    Yeah I was gonna suggest you read through that and see if any similarities.
    I gave up on that long time ago and just left it as is checking coolant periodically . Mine leaked minimal amount and wasn't getting any worse.
  9. The Following User Says Thank You to Hodge For This Useful Post:
    King_ady1 (5th November 2015)
  10. #38
    477 Post(s)
    Follow that hose and i reckon it goes to the oil drain tray which is under the oil filter.
  11. #39
    Beveridge, Victoria
    That's probably it... It was quite oily at the tip. It's only 2 inches long and goes to a black box under the oil filter... Lol makes sense. Just wanted to confirm it's suppose to be like that
  12. #40
    Beveridge, Victoria
    Ok... So I guess I have a strange leak as well. No coolant leak at all since that day... I guess if it ain't broke, don't fix it??
    Also have the gauges all finished and wired. Took my time and did it with minimum stress.
    Ran all wired, probes, pressure hose under wheel to the receiver. Pulled the small panel under steering wheel off (1 screw and 4 bolts) and off she pops. Velcro and some hot glue to stick the receiver on, when off was easily able to access dimming switch(plug) and wired gauges onto it. Nice and easy quick piggyback fuse circuit for power and all sweet. Wire conduit for keeping it all need and pack up. Except for the one panel I didn't have to pull dash apart. All happy on that note.
    Now to decide on the next little project
    Uhf,
    Winch,
    Light bar,
    DVD headrest,
