Results 11 to 20 of 50
Thread: Air compressor in rear
    Just make sure you have the correct wire size for the run to the rear.
    A long way from the battery and they pull a few amps when working
  2. The Following User Says Thank You to threedogs For This Useful Post:
    04OFF (24th October 2015)
  3. #12
    Yep, already catered for.
  4. #13
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    You can get a diff oil smell in the car if you don't set up the plumbing to vent properly, I think ARB sell the kit to stop it happening
  5. #14
    Quote Originally Posted by liftlid View Post
    I think they have sorted that now Gary, mines under the seat and I haven't smelt anything.
  6. The Following 2 Users Say Thank You to AB For This Useful Post:
    Hodge (24th October 2015), liftlid (24th October 2015)
  7. #15
    Surly not that hard to put one together..
    Run a small tube from exhaust port threw a grommet with a filter on the end..
    No probs mounting it in the rear just need to modify the loom which I'm sure you'll be right with.
    Pros of under bonnet - Closer to battery, loom will reach everything, quieter, no smells (don't no how much of an issue this is anyway), more room in cab. Pros in car - more room under bonnet closer to rear (but you can get extension hoses), cleaner so better for compressor.
    Have fun, you'll love the ARB one they're a bloody good unit. . .
  9. The Following User Says Thank You to Rossco For This Useful Post:
    Winnie (24th October 2015)
  10. #17
    Its called a Pro-Locker lol
  11. #18
    Nov 2010
    6 Post(s)
    Good luck lol
  12. The Following 4 Users Say Thank You to liftlid For This Useful Post:
    Hodge (24th October 2015), Rossco (24th October 2015), threedogs (24th October 2015), Winnie (24th October 2015)
  13. #19
    Are you going to run a small hotdog style tank for the locker???
  14. #20
    No, not needed. I can deal with the compressor kicking in for 5 seconds every 15 mins or so.
  15. The Following User Says Thank You to Winnie For This Useful Post:
    BigRAWesty (24th October 2015)
