Results 11 to 20 of 21
Thread: Building drawers for my GQ.
    Advanced Phill265's Avatar
    Jun 2015
    Well that worked out alright westy, old man has a couple GU and he's going to buy 2 locking sliders off me. Get a set of drawers made for himself. So now I'll order 2 none locking ones. Covered me there, thinking it would be a bugger with two locking on each draw
  2. The Following User Says Thank You to Phill265 For This Useful Post:
    BigRAWesty (24th October 2015)
  3. #12
    Jun 2015
    Well progress so far, pulled carpet out. Painted the floor with white kill rust, and put silicon in all the unwanted holes. Punch 6 holes in carpet for slates and brought longer bolts to go through slates into existing bolt holes.
  4. The Following User Says Thank You to Phill265 For This Useful Post:
  5. #13
    Quote Originally Posted by Phill265 View Post
    Yea I built my self and father inlaw a slide for our cf50's and hind site should have only bought 2 locking instead of 4..
    It's just a pita with to..
    Jun 2015
    Yeah just a bugger lifting two up, and trying to get the drawer out.
  7. #15
    Jun 2015
    Next up cut 6 slates of 12mm ply at 30mm wide. Glued 2 together to make 3. Trimmed the one just behind the seat to make lvl, then added a small block in the centre of it for support.
  8. #16
    Jun 2015
    Cut floor to size, then drilled holes round bolts for easy access
  9. #17
    Jun 2015
    With the bench saw cut a 6mm x 13mm recessed edge on top and bottom. Made a couple square edges, with holes to clap square with, glued and screwed together
  10. The Following User Says Thank You to Phill265 For This Useful Post:
  11. #18
    Jun 2015
    screw runners in went with one locking one, and one non locking slide per draw as suggested.
  12. #19
    Jun 2015
    boxed the drawers and screwed them to runners
  13. The Following User Says Thank You to Phill265 For This Useful Post:
    DX grunt (20th October 2016)
  14. #20
    Jun 2015
    place drawers on base screwed down, made wings wrapped in marine carpet.
