Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 104
Thread: My ls conversion...
  1. #51
    Expert mullet_hunter's Avatar
    Feb 2015
    perth.. norf of the rivr..
    Was going to run and single 3 inch but im thinking twin 2 and a half inch... using advanced headers..
    Sent from my SM-N915G using Tapatalk
  2. #52
    I heard a Y62 patrol the other day with a twin system
    very loud,,,,,,, all I could say was WOW.
    If you can get a twin system to fit that would be awesome
    better for a V8 too IMO one pipe per bank
  3. The Following User Says Thank You to threedogs For This Useful Post:
    mullet_hunter (21st October 2015)
  4. #53
    Feb 2015
    Looks like i need to upgrade my airbox too.. going to get one frm fatz fabrication... same as this pic...
  5. The Following User Says Thank You to mullet_hunter For This Useful Post:
    BigRAWesty (21st October 2015)
  6. #54
    As long as the heat Shield works..
    Why doesn't the stock zd box fit??
    Does it differ much from the td vertical box?
    Feb 2015
    The zd box fits... but its highly restrictive with the ls.. they like to breathe..
  8. The Following User Says Thank You to mullet_hunter For This Useful Post:
  9. #56
    Feb 2015
    Sime lazy sliders i was knocking up for the pooey and the bro's prado..
  10. #57
    Feb 2015
    This brake line needs to be moved as it will faul the aircon...
    Like so...
  11. #58
    Mar 2013
    NE Melbourne
    I sat in a Y62 that had butterfly valves porting the exhaust strait out of the pipes before the mufflers. It was LOUD and sounded fantastic!
  12. #59
    Beginner alien_racing's Avatar
    Do you have any pics of the fuel lines? Did you just bend them out or cut and join?
  13. #60
    Feb 2015
    Ye you just move them from the side of the chassis rail to the top side... the heat shield will will cover everything ontop of the chassis rail... dont cut them... im gona use speedflow fittings that go streight frm the hard lines to dash 6 fittings.. and frm there to my regulator/filter then onto my fuel rail...
