Results 1 to 10 of 14
Thread: Towing question
    Expert LaughingBeagles's Avatar
    Mar 2015
    Towing question
    Hi all,
    I wasn't sure where to post this so apologise if I missed the mark.
    After a fair bit of negotiating, I have purchased a campertrailer from a bloke in Victoria.
    This is it here:
    http://www.gumtree.com.au/s-ad/seafo...215970?ref=ais
    We are thinking of driving over to pick it up around Nov. I have asked him for photos of the trailer pin (I know Vic and WA are different) so will likely need to buy one of those converters for now.
    Now to the question. I have a 2" lift kit and was wondering what the best way is to compensate for the trailer not having it? Do I not bother for now or do I need to get a tow ball that's dropped a bit? Slightly longer term, I might lift the trailer to match, but in the interim, what's a good idea?
    Pete
    Looking for a 4WD Club in WA that caters solely for Patrol, Safari and Maverick owners? Click here to HERE to visit the Western Patrol Club. Click HERE for the Beagle Mobile Mods!
    You can turn the tongue upside down and re-bolt your towball on top.
    Thats how I get my camper trailer even,
    Your tongue if a class 2 Hayman reese style will have a 50mm difference
    LaughingBeagles (11th October 2015)
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Is your axle over or under the spring?? Putting it under will give you a couple of inches extra height...easy conversion too.
    Also, see if you can get same wheel/tyre as the Patrol on it, saves caring extra spares
    EDIT: assuming itsa leaf spring configuration
    ________________________
    ______ 2017 D-Max _______
  5. The Following User Says Thank You to Maxhead For This Useful Post:
    Mar 2015
    Thanks Lads. In the first instance, I'll go with 3D's. It's a standard Hayman Reece style so it should do the trick.
    Expert 92GQ's Avatar
    Sep 2013
    Qld
    Just a thought, If you lift the camper to much the tent won't reach the ground anymore.
    1992 TD42 GQ Patrol Wagon
    My GQ Build Page
  8. The Following 3 Users Say Thank You to 92GQ For This Useful Post:
    AB (11th October 2015), LaughingBeagles (11th October 2015), Maxhead (11th October 2015)
  9. #6
    ACT
    Quote Originally Posted by 92GQ View Post
    Yep good point. I was able to do it to mine as it had enough height to spare
    If you go down this path
    LaughingBeagles you'll need to make sure you have enough tent...LOL
  10. The Following 2 Users Say Thank You to Maxhead For This Useful Post:
    LaughingBeagles (11th October 2015), threedogs (11th October 2015)
  11. #7
    I wonder how many people have done that not thinking and not realised until the first camping trip set up...oh crap!!!
  12. The Following User Says Thank You to AB For This Useful Post:
    92GQ (5th January 2016)
  13. #8
    Thomastown, Melbourne
    6 Post(s)
    Was the first thing i thought of. .. i have 2 different tow tongues of different offset depending on the trailer i tow.
  14. #9
    Nov 2010
    Getting a life...
    38 Post(s)
    And you should ask seller to remove the ad, so he doesnt sell it from under you.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  15. The Following User Says Thank You to katwoman For This Useful Post:
    LaughingBeagles (13th October 2015)
  16. #10
    As far as Vehicle Trailer Plugs go I use 12 pin flat
    You then fit the Trailer with either 7 pin (under 750 KG and no aux services IE trailer has stop tail and indicators only) or 12 pin (over 750 Kg or has Aux services IE eleccy brakes, aux batteries etc)
    12 pin flat accepts a 7 pin flat and has the same pin assignments so no adapters needed.
    12 pin also has the maggy switch to tell vehicle Canbus etc that a Trailer is connected and/or disables reversing sensors
  17. The Following User Says Thank You to the evil twin For This Useful Post:
