Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: What is the redline for a TD42?
    22 Post(s)
    Quote Originally Posted by SKID View Post
    No idea, I've only owned the truck for about 2 months, the conversions was done by the previous owner...
    That dosnt help at all.
    If you have a larger turbo and pump the boost falling away isnt right and could be cause by a number of things.
    If it is a smaller turbo that works in the low rpm, then yes, it will fall over in the higher rpm,
    A bit of smoke off boost is normal, you need fuel to make heat, heat to make exhaust gas velocity, velocity to make boost,
    Too much smoke isn't right and could be tune related, amongst other things
    96 GQ coil/Cab
    08 G6eT
  2. #22
    Mar 2013
    Looking at the turbo on the exhaust manifold, it doesnt look all that big
  3. #23
    Hardcore
    central coast nsw
    put some injector cleaner threw it.
    and not sca cleaner, stick with a brand name if possible.
    and if they recommend doubling the dose for faster better clean don't hesitate doing so.
    check your air filter also.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  4. #24
    Mar 2013
    Noticed today that mine finds it hard to rev past 3000RPM
  5. #25
    Mine will do 4500.... but that's low second.. and that's about where the red line starts on the tacho. .
    It's bloody screaming when up there so I don't do it for long.
    But I have no power so any big sand hills..
    It sits on 3000 happy as when towing up long hills. It's usually in 3rd high and 60-70km/h.. again. No power so need to use rpm..
    Nov 2013
    Gold Coast
    Even with a schwitzer turbo mine used to run out of grunt at about 2 to 2500 rpm. Somewhat embarrassing.
    Amazing what a difference there is if one replaces all the rubber fuel lines before the fuel filter so the engine does not get to suck air into the lines at higher revs.
    Apparently the fuel pump didn't like air bubbles mixed in with the fuel either!
    My mechanic has nearly finished his 4.2 rebuild and he is expecting 6 to 6500 rpm. I'll continue to accept my 4 to 4500 rpm and save a heap of $s.
    The old rubber fuel lines looked good to me but I guess thats why the guy who services mine services mine.
    Chimo
  7. #27
    WA Wheatbelt
    23 Post(s)
    Thats interesting. I turn mine to 4200-4500 each time I drive it. My redline on my dash is at 4500.
    My redline on my dash starts at one notch over 4500, so I'm guessing it's either 4500 or 4600.
    Mine's a 2005, 4.2 TDi, ute.
    Rossco
  8. #28
    Rossco
    Yeah, but your needle doesn't move 'cause it's rusted stuck to the zero stop (tish boom)
  9. The Following User Says Thank You to the evil twin For This Useful Post:
    Winnie (7th October 2015)
  10. #29
    Mar 2013
    Will it free rev to 4000rpm?
    Mine will free rev to 4000+ but when driving am flat ouot getting it to 3000 and it feels like its missing or starving for fuel.....
