Results 11 to 20 of 35
Thread: Which brake pads?
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    I use Bendix 4wd SUV Hybrid they pull up good
  2. #12
    Patrol Guru blocko05's Avatar
    Apr 2015
    Hobart TAS
    A soft pad will be quiet but make a big mess but a hard compound pad will be noisy but less of a mess. Bendix make great pads and they have a huge range to select from. Repco sell them. If you start with a set of DBA rotors with "Kangaroo paw" internal pattern are great. You can buy cross drilled or slotted. Had these on a race car and they worked a treat. They will disperse heat quickly and are as strong as. If you have 4 spot calipers even better. A soft pad will be quiet but make a big mess but a hard compound pad will be noisy but less of a mess. Bendix make great pads and they have a huge range to select from. Repco sell them.
  3. #13
    Bendix for me as well. Got the HD ones and flushed the fluid. Pulls up well.
  4. #14
    Ballarat, Vic
    177 Post(s)
    I have RDA dimpled/grooved rotors plus EBC Greenstuff 6000 series pads. Definite improvement over stock & I’d buy them again.
  5. The Following User Says Thank You to Cuppa For This Useful Post:
    Rocket55 (13th October 2015)
  6. #15
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Did anyone else see this in the current supercheap catalogue? Does it extend to their 4wd pads as well?
  7. #16
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    I have also been using Bendix for many years.
    "Bacho" I seen that catalogue and checked today at my local SC. I was told that the special was only for in store stock.
    They had the Bendix for the front in store but don't keep the Bendix rears, so the deal does not apply.
    Interested to know if any of their stores keep front and rears.
    Was a CRD
  8. #17
    Did you go with the set up in the link??
    A few here run ADR braided hoses with great pedal feel
    Not too pricey $$ well for my model.
    http://www.nissanpatrol.com.au/forum...formance-Lines
  9. #18
    Mar 2011
    14 Post(s)
    Quote Originally Posted by ova50 View Post
    Yeh I was just in the bayswater store this morning and couldn't find the right product either.
  10. #19
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Which brake pads?
    Yeah, went with the same setup as the link I posted.
    So far the braking is great but been towing a lot so not 100% tested yet
    Braided lines will be next I reckon as the pedal is still very soft
    ________________________
    ______ 2017 D-Max _______
  11. The Following User Says Thank You to Maxhead For This Useful Post:
    threedogs (1st October 2015)
  12. #20
    Is it a big job fitting the braided hoses, its beyond me atm as I cant get under the patrol,
    Do you need one of those 4 in 1 bleeder hoses??
