Page 548 of 1057 FirstFirst ... 546547548549550 ... LastLast
Results 5,471 to 5,480 of 10566
  1. #5471
    John Bennet used to put brass impellor on his water pumps.
    That brass looks the ducks guts imo that'll shift some water,
    does it have a better flow rate over OE.
    John bennet pumps were all die grinded so that internal surface
    was flat and smooth so there was no chance of cavitation, might be worth a try
    Better than those press tin jobs
  2. The Following User Says Thank You to threedogs For This Useful Post:
    Bloodyaussie (20th September 2015)
  3. #5472
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Bought a can of MAF sensor cleaner and cleaned the MAF. Had a bit of crap on it and I think it actually made a difference to performance. Taking numbers down now to see how fuel consumption has changed if at all but drives nice anyway.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  4. The Following User Says Thank You to Chubba For This Useful Post:
    jay see (18th September 2015)
  5. #5473
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    welded some of its rear bar together ...
  6. #5474
    Patrol Guru Rocket55's Avatar
    Sydney
    Gave it a wash.
    Cheers Rod
    My Build 2005 TD42TI
  7. #5475
    Expert Majestic's Avatar
    Oct 2014
    Central West NSW
    Over the past few days I've:
    Replaced the main seals on the engine, both front and rear.
    Replaced the clutch
    New handbrake shoes and second hand drum
    Got some extractors and put them on.
    Full service including replacing the gearbox oil, she sure needed it.
    Washed her.
    Owner of 1984 SD33T MK Patrol
    Owner of 1989 TD42 GQ Patrol
    Previous Owner of a 1988 TB42 DA Maverick
  8. The Following User Says Thank You to Majestic For This Useful Post:
    Stropp (16th September 2015)
  9. #5476
    After changing the back two glow plugs I noticed my boost was down a bit, strange as I was no where near any boost lines.
    So this morning off came the intercooler for a look, seems the nylon boost hose where it goes into the boost side of things has cracked where the brass olive is.
    Not having a spare I drilled out the old one, works for now but brought a boost gauge adaptor so it sits under the OE boost sensor.
    Boost nearly hit 30 with no limp but no gain in performance so backed it off to 18psi.
    Not a spare I would normally carry [brass olive] so Ill change the way I get my boost as I dont want this the break out bush. pitb
    Just a thought is you have boost issues with gauges fitted
  10. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    Sir Roofy (16th September 2015), Stropp (16th September 2015)
  11. #5477
    Not sure wether to post here or in the happy thread.
    Got the gq back from the pannel beaters this morning.. no more rust in the gutters, roof or windows.
    Have just primed and coated black with spray can for now. Going to do a full re spray threw summer. Stay tuned. Lol
    While it was apart I took to opportunity to line the roof with some "excess" sound deadening foam that I "over ordered" for the canopy. Wink wink.
    I didn't however realise I had enough to do the whole roof. Lol
    Doesn't look pretty but who cares when it's behind the roof lining.
    Super stoked.
  12. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Woof (18th September 2015)
  13. #5478
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Washed all the mud and grime off after adding 4400km to the odometer after driving from Adelaide to Gawler Ranges, Head of Bight, back to Ceduna, up Goog's Track, across to Kingooya, up to Coober Pedy, Oodnadatta, over to William Creek and Halligan's Bay Lake Eyre, finishing up in Arkaropla and Willow Springs before ckming home. Now avidly planning the next trip. .....
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
  14. The Following 3 Users Say Thank You to AJTich For This Useful Post:
    BigRAWesty (18th September 2015), Hodge (18th September 2015), TPC (18th September 2015)
  15. #5479
    Quote Originally Posted by AJTich View Post
    How many weeks did you take for that tich?
    Oct 2013
    Andrews Farm
    Only had 17 days...but still had time to check so much out... Work next week..:-(
    AJTich
