Page 29 of 43 FirstFirst ... 2728293031 ... LastLast
Results 281 to 290 of 430
Thread: Bloodyaussies TD42 a new beginning
  1. #281
    Quote Originally Posted by Bloodyaussie View Post
    I dont know where to start with the kinugawa turbos... my turbo is too big so dont want to make the same mistake again.
    if funds are tight then why don't you go back to a ht18 for now and save for a bigger pump and turbo later on mate.
    You'll get one cheap cheap for now and do everything you need for a couple of years.
    Your pump will only do so much so save and go the full upgrade later on.
  2. The Following 2 Users Say Thank You to AB For This Useful Post:
    Bloodyaussie (7th September 2015), Winnie (7th September 2015)
  3. #282
    North brissy
    This is probably the best option really.
  4. #283
    Thomastown, Melbourne
    6 Post(s)
    How cheap??? then I would have to stuff around with set up and dump pipe????
    Where are these cheap ht18's
  5. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    Hodge (7th September 2015)
  6. #284
    How cheap??? then I would have to stuff around with set up and dump pipe???? Where are these cheap ht18's
    If Matty comes clean with his new set up I'll sell you mine reallll cheap
  7. The Following User Says Thank You to AB For This Useful Post:
  8. #285
    22 Post(s)
    It burns not knowing doesn't it
    96 GQ coil/Cab
    08 G6eT
  9. #286
    Lol...yes and no
    I know I can't afford it at this point but I've been saving for a while now and know when he's done I'll be ready
  10. #287
    6 Post(s)
    I would love to also change to a low mount set up but the manifolds are few and far between it seems.
    AB I dont know what you are dribbling, it all sounds like secret code to me.
  11. #288
    North brissy
    Looks like we have found someone to test out the size under the one I'm using so should be interesting.
  12. #289
    what's wrong with your one? Too much???
  13. #290
    North brissy
    No its fine but would probably suit a 12mm pump to really get the most from it. The size under can still produce enough air to support 200rwkw but could be a nice option that could be used with a 11 or 12mm pump.
  14. The Following User Says Thank You to nissannewby For This Useful Post:
    AB (7th September 2015)
