Page 27 of 43 FirstFirst ... 2526272829 ... LastLast
Results 261 to 270 of 430
Thread: Bloodyaussies TD42 a new beginning
  1. #261
    Thomastown, Melbourne
    6 Post(s)
    Exhaust side of turbo?
    The gasket where the vband bolts up to yhe exhaust side.
  2. #262
    If its a proper v band it shouldnt need a gasket. But a small smear of some copper gasket hi temp should be fine.
  3. #263
    6 Post(s)
    Ya sure there is no gasket??
    I dont mean the vband itself but where it bolts too the turbo??
    I know how much you like??????????
  4. #264
    So you have a 2 piece turbine housing? A v band part that is bolted to back of turbo?
  5. #265
    6 Post(s)
    Yes that is correct..
  6. #266
    Ok. Just use some hi temp sealant. I have bolted a couple together with nothing and they have been fine. How many bolts hold the flange on?
  7. #267
    6 Post(s)
    I am not sure at the moment... there is a heat sock thing over it and i have a cracked rib .
  8. #268
    6 Post(s)
    This is where the leak is....
  9. #269
    22 Post(s)
    Thats similar to mine, I dont have a gasket and it doesn't leak, they are machined surfaces. If you can find a gasket it wont hurt. But while it is apart just make sure the surfaces are flat
    96 GQ coil/Cab
    08 G6eT
  10. #270
    6 Post(s)
    Yes getting the surfaces done tomorrow..
    What do you guys think of those $900 turbos... mamba and the other brand i cant think of the name.
