Results 1 to 6 of 6
Thread: Knuckle spindle thread damaged.
    Apr 2013
    newcastle, nsw
    Hi guys/gals I have been searching the forum and web and can't seem to find any info regarding the patrols knuckle spindle thread.
    Just after what type of thread size the spindle has as one of the spindles has been damaged due to a bearing failure and I don't want to dish out 300-400 bucks for a new/ restored one. It's much easier and cheaper to re tap the damaged thread as it currently is the only bad part.
    Thanks in advance for any help/information.
    Can you use a thread file to re-store the thread, they cost around $35 for memory
    but a handy bit of kit. even a set of needle files may help in restoring the thread.
    Worth a try imo
    Timbo15 (6th September 2015)
    84 Post(s)
    A good fasteners store should
    have a thread gauge so you
    can get the right die or thread
    file.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Apr 2013
    newcastle, nsw
    thanks I will try both of them ideas.
    84 Post(s)
    If there has been any
    heat discolouration
    in the spindle due to
    the bearing failure
    replace it.
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Just get one from the wreckers.
