Nice one stirlo! That's what I'll most likely do with mine. I was just gonna drill all the tabs so I could put one wire through and solder up.
GQ Patrol, TD42 NA, 33's, Snorkel, 2" inch lift, Dual Batteries, Roof Rack, Awning... Many more to come
yer otherwise just fold all tabs but not the last one. put 2-3 cable ties to hold it in place and then solder like crazy, then fold the last tab over the tab of the wire. - that is what i did :P
what a great idea Stirlo, thanks for that
Just BE SURE TO USE A INLINE FUSE ON IT! Between the battery and the fuse box use a maxi fuse or circuit breaker. Example: If you have a 8 slot fuse box all 8 slots coming off a single soldered cable (photo above) and all things are 10amp fuses. thats 80amps if all are turned on at once. Keep it inmind guys and be safe! I use a Maxi Fuse 100amp to protect it![]()
Yeh I will inline fuse it. Although several auto sparkies I talked to said not necessary if its an auxiliary battery running just LED's and a fridge all earthed and fused correctly... Mind you I do live in the Kimberley so safety is of no great worry up here haha
ashmccormick (4th September 2015)
This is exactly the unit I have. Best money spent on 12V. Keeps stuff neat and tidy. On my grenade I had one under the hood for front lights, compressor etc... And one at the rear for fridge, camping lights etc... Willl be wiring up a similar setup this time around again.
Bigcol (4th September 2015)
