Page 41 of 50 FirstFirst ... 3940414243 ... LastLast
Results 401 to 410 of 498
Thread: Outback Ideas Recovery points
  1. #401
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    Hey TD, what type would suit my 2006 4.2 GU mate, have taken some photos
  2. The Following User Says Thank You to Woof For This Useful Post:
    Hodge (27th August 2015)
  3. #402
    Quote Originally Posted by Tuppa View Post
    bloody hell Doggy, wash your car mate!!!!!!! hahahahaha
  4. The Following User Says Thank You to Clunk For This Useful Post:
    Woof (27th August 2015)
  5. #403
    @ Tuppa good news and bad, You have the one motor bar combo I cant fit one of my points to.
    Good news is I have a proto type thats nearly finished, I'll get some MDF samples cut and post to either
    yourself or OD to check for fitment,
    I know of no one with the same combo over this way, but a few members have the same.
    Ill PM when I have the MDF samples.
    Its all to do with that 30mm lip, personally I'd cut it off and fit my "tee" shaped ones,
    but some dont like cutting bits off their Patrol lol
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Woof (1st September 2015)
  7. #404
    Hi all just an update , the Y62 are being cut and should fit first time and very strong IMO.
    Also for ppl with the model/ bulbar combo like Tuppa Ive gone to the Laser cutters and picked up some MDF samples.
    As OD has the same combo I'll either fax or email what I have so he can adjust to suit, all I know is the hole centres are right
    just not quite in the right position. So bear with me for a while and I'll have points to suit all GU's regardless of the combo.
    Its difficult getting hold of all the different Patrols as you could imagine.
    FYI the Y62 I'm looking at has already done the front pinion seal and CV seals , bloody thing is brand new
    Must admit he is ex comp truck driver[very good] so pushes hard off road.
    Yet no excuse to be blowing seals, this Y62 is having a blower fitted soon
  8. #405
    Patrol Guru Rocket55's Avatar
    Sydney
    3 Post(s)
    That's the same as mine Tuppa.
    Cheers Rod
    _______________________________________________
    Bitumen ...... Another watse of public funds
    My Build 2005 TD42TI
  9. #406
    Quote Originally Posted by Rocket55 View Post
    Hey Rocket you have the T one's is that right.
    Tuppa cant fit them as there is a 30mm lip near the two bolts
    on the third picture
  10. #407
    Sydney
    3 Post(s)
    No mate, mine is exactly the same as Tuppas, 2005 TD42Ti with and ARB bar with that lip on it.
    Cheers Rod
  11. #408
    177 Post(s)
    I'm pretty sure mine are the same John as I have the same combo. So without chopping it won't fit ??
    177 Post(s)
    Just had a quick look and unsure whether I'm doing something wrong here but this doesn't look like it would fit ? Thoughts TD ???
    That bit of metal i circled in red on second photo, the poin'ts wont make it in there with that there ? Am i lining these up wrong or ?
    177 Post(s)
    Here is a bretter photo of the prior one. Circled in red is the bit of metal in the way. Fair bit of metal off the bull bar bracket.
