Page 117 of 187 FirstFirst ... 115116117118119 ... LastLast
Results 1,161 to 1,170 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1161
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Yeah I reckon I could. I used a hole saw so it's a nice neat hole. Not sure how much would enter there versus the rest of the engine bay though? Will check it out though cheers.
    Probably only a little bit more I guess but it would be roosting in off the tyres
    Hello from Under Down Under!
  2. #1162
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Isn't that why there's a hole cut there?
    My old body mounts allowed the body to hit the frame and steering box on hard hits, and that's with standard shock towers, I was going to cut out the entire hump to install extended shock mounts
  3. The Following User Says Thank You to liftlid For This Useful Post:
    taslucas (24th August 2015)
  4. #1163
    334 Post(s)
    Yeah the shock tower is hard against the body now. Had to manipulate the drivers side a little but all in now.
  5. #1164
    334 Post(s)
    Biggest issue for me was how I was going to get to the top nut on the shock but the hole sorts that out.
  6. #1165
    Aug 2011
    North West Tas
    56 Post(s)
    I've seen you lebo slingshot liftlid and I'm surprised the body is still attached at all let alone punched through with holes!
    tappa lives!
  7. The Following User Says Thank You to taslucas For This Useful Post:
    liftlid (26th August 2015)
  8. #1166
    Apr 2015
    Hobart TAS
    Hey Mudrunner just had a quick question about when you moved the primer pump back over to the drivers side (roughly page 110 I think) . Did you take the wring for the water in fuel plug with it or not worry about it? If so, how did you do that. Just about to do the same on mine and after any tips. Cheers.
  9. #1167
    334 Post(s)
    Quote Originally Posted by vocal View Post
    Hi mate, sorry I completely missed your post. Sorry for not following you up.
    I have run an after market fuel filter for 10 years with a water separator so the wiring is obsolete on mine. Would not be difficult though I would think. Knowing Nissan it probably leaves the loom on the drivers side and goes across the fire wall anyway.
    Hope you got it sorted mate/ feel free to ask away.
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (16th October 2015)
  11. #1168
    Apr 2015
    Hobart TAS
    Nah all good mate. Yeah pretty sure it is in the loom on the drivers side and just goes across the inside of the firewall and then out the other. Haven't got around to it yet as have had bigger dramas. Cheers though.
  12. The Following User Says Thank You to vocal For This Useful Post:
    MudRunnerTD (25th November 2015)
  13. #1169
    334 Post(s)
    What have we got here?
    48.3 OD pipe. Hmmmmmm
    And a nice bender!!!
    Time to get busy!
    Brush bars for the GQ and GU
    Making Sliders for the GU
    Tomorrow is going to be a great day!!
  14. The Following 6 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (30th January 2016), BigRAWesty (30th January 2016), jay see (31st January 2016), NissanGQ4.2 (30th January 2016), Plasnart (30th January 2016), Winnie (30th January 2016)
  15. #1170
    334 Post(s)
    Woo hoo! Are you a stick or mig kinda guy?
    Going to mig it. Think I will dump the gasless wire and fit gas wire and small bottle see how I go.
  16. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    mudnut (30th January 2016), Plasnart (30th January 2016)
