Results 11 to 20 of 24
Thread: Boost Guage line
    Expert nickpeacock36's Avatar
    Oct 2010
    North Lakes Qld
    Quote Originally Posted by YNOT View Post
    Took me a while to find the photo but here it is;
    Tony
    Where does the other pipe go Tony?
  2. #12
    Quote Originally Posted by nickpeacock36 View Post
    Which other pipe?
    One side of the brass T-piece goes to the boost gauge, the other to the dawes valve. Is that what you meant?
    Tony
  3. #13
    Oct 2010
    North Lakes Qld
    The thread on the fitting i was supplied looks fine to be a standard metric, do you know if its a special thread?
  4. #14
    Oct 2010
    North Lakes Qld
    Which other pipe?
    Tony
    Yes that is what i meant. i just posted about thread. can i change to a t later easy?
  5. #15
    Oct 2010
    North Lakes Qld
    Can you use the guages before connecting up the electric? i assume power is just for the lights.
  6. #16
    The thread I welded/brazed in was a standard (1/4 npt I think) thread, it's the same thread on both ends of the T-piece, so yes, if you do that it's a simple case of unscrewing the boost gauge line, fitting the T-piece and screwing the boost gauge line into one end of the T-piece.
    Tony
  7. #17
    Correct, VDO boost gauge is mechanical, the wires are just for the back lighting.
    Tony
  8. #18
    Oct 2010
    North Lakes Qld
    Tony
    Thanks Tony, is that the same with the pyro?
  9. #19
    No, the pyro has a thermocouple sensor so will not work without power.
    Tony
  10. #20
    Oct 2010
    North Lakes Qld
    Tony
    Got the boost guage working sort of. I stuffed the olive up that goes into the cooler but managed to fit one from a bike brake system temporarily. The guage makes an annoying rattle noise when it's returning to the 0 psi point. Is this normal?
