Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 91
Thread: DIY: Scan, calibrate and import a Rooftop Map for use in Hema/Memory Map software
  1. #51
    Thank you so much Drew, just finished scanning and uploading a heap of Rooftop maps to my tablet. Awesome write up would have been very lost without it. First map took about 2 hours of friggin round, the rest were heaps quicker.
    A few things I encountered were, firstly Officeworks would not scan due to copyright, so ended up using Snap Printing who happy to do them. Also noticed it was doing random things with the waypoints - it kept changing when it saved one. Worked out that I was missing a number at the end so Eastings and Northings had to be 7 digits long Eg. 55S 5320000E 5911000N. It seems weird that Memory Map uses UTM zone 55S instead of 55H which all other maps use for that region. That would have taken me for ever to work out if ever, sure that would have driven you very crazy Drew, but thanks it has saved a lot of time. Also found loading was very easy being Android, just had to copy and paste the files straight into the Memory Map folder on the tablet which works fine.
    Have tested a couple in the bush and they work very well, its so good having quality Rooftops maps with reliable track and other info and knowing where you are. Still good to have the paper maps too tho.
  2. #52
    Oct 2011
    Essendon
    Yeah Rosco, it's weird how some places will scan them no problems and yet others get their knickers in a twist about copyright. The officeworks near me do it no probs
  3. #53
    Oct 2013
    Port Hedland
    Have to say great thread Drew. I am new to the memory maps and only found it because I wanted to see if I could scan some maps and use them on my tablet GPS.
    Has anyone done this with an Android?
    I am using a Samsung tablet and pc using the trial version.
    I have followed your steps on the PC Drew(Legend) but having issue putting it onto my phone.
    I have calibrated it and put the route border around it but for some reason when I put the files on my phone in the folder the map wont show up in the " more maps" tab. if I go into the folder and click the .qct file it shows up but wont track with the GPS
    I think I have followed all Drews steps?
    In the folder I have .mmo, .gpx, .qct.txt, .qct, .jpr, .tif files
    The MMo and GPX are only small files and exported them through the PC.
    Quote Originally Posted by cjb View Post
    Hey mate, Rossco has them on his Android tablet with no dramas so hopefully he might be able to help you.
  5. #55
    Hi mate Yeah i have scanned maps on my samsung tablet with mm . When you say phone are you putting them on both tablet & phone or just tablet? Not sure how many devices you can have with a licence. Did they calibrate correctly, it did take me a bit of stuffing around to get it right, was missing a digit out of the eastings & northings and it was doing funny stuff. Does it show the correcet location of the cursor reative to the map in the bottom toolbar when you move the mouse on the pc? On the tablet once you press "all maps on device" then "map types" is the "tiff" box checked? Good luck these things can be bloody frustrating (for me anyway!!)
  6. #56
    Oct 2013
    Port Hedland
    Hey Rossco
    I got it working with the calibration e,n are right i just cant get the first three digits to change.
    I enter 50K and it reverts to 50N which puts the map perfectly above where i want. Except its just off the north east coast of Malaysia.
  7. #57
    Ahh. . . Yeah memory maps UTM zoneing is a litte weird for some reason. Where are you, or the maps you are putting on? The maps for most of Vic (eastern vic) are zone 55H but memory map works when set at 55S. Try getting up the hema base map on the pc then pointing the cursor in the vicinity of the maps and check what the UTM zone (first 2 numbers & letter) is, then use to calibrate. . . Hopefully that's works! !
  8. #58
    Also check eastings & northings are 7 digits each. I was using 6 and it kept changing to something different when i saved point. Took a bit to work out & was very annoying! !
  9. #59
    Oct 2013
    Port Hedland
    Thanks Rossco
    Threw my hands in the air last night.
    I will have a crack tonight with your tip.
    Thanks Rossco
    Yeah fair enough, sometimes it's best to walk away from these things and come back with a fresh head. . . It can drive you very crazy!! Hopefully it works soon. . .
