Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Coleman Hot Water Service Power Supply, run when battery is dead
    Sounds like my battery is on its way out then.
    I would get a third of that usage time ET!!!
    Replacement battery is about $20 to $40 depending who you wish to patronise.
    The battery should last for about an hour depending on useage pattern
  2. #12
    Don't worry ET. Andy has reeeaaaaaally really long showers
  3. #13
    Showers or Enemas?
    He'll need to choose one or the other...
  4. #14
    Showers or Enemas?
  5. The Following User Says Thank You to AB For This Useful Post:
    Rossco (20th August 2015)
  6. #15
    Did you get any love with this post Flex?
  7. #16
    Ballarat, Vic
    178 Post(s)
  8. The Following User Says Thank You to Cuppa For This Useful Post:
    AB (20th August 2015)
  9. #17
    Advanced Flex's Avatar
    Sep 2011
    Melbourne, Australia
    AB, as cuppa pointed out no one really wants a custom solution. My unit did have the features like automatic switch over and under/ over voltage shut off, but for less than $10 off eBay for a simpler 12V -> 6V converter my solution wasn't worth it for most.
  10. The Following User Says Thank You to Flex For This Useful Post:
    AB (21st August 2015)
  11. #18
    Nov 2014
    Waikiki, WA
    Our simple solution when remote and water is very precious is to recycle the water and get two showers with only 10litres of water.
    Modified the van shower adding an additional 12V pressure pump fitted NRV's prevent shower water polluting van supply.
    Heat up a bucket of water over the camp fire tip it into the shower recess start pump and you can shower until the water runs cold.
    Dump when finished and you're ready for following day.
    2002 ST Coilcab, Chevy 6.5 V8 Garrett turbo, intercooled. 3.9 diffs, Cooper AT3 265/75/16.
    Trailstar Aquila 5.4
    http://s4.zetaboards.com/Gold_Detecting/index/
    http://www.youtube.com/watch?v=y7GCkFcHsh0
