Page 40 of 50 FirstFirst ... 3839404142 ... LastLast
Results 391 to 400 of 498
Thread: Outback Ideas Recovery points
  1. #391
    I'll take a pic for you when I get home
    threedogs (19th August 2015)
  3. #392
    To run two which I highly recommend you'd need to drop
    the bar and make a plate to fit inside the left hand chassis.
    Nuts required to weld to plate are 14mm x 1.5 pitch,
    Hard to find zinc plated bolts but spray can is ok.
  4. #393
    Big thanks to Rusty-Nail for re-doing my first page, looks neater and explains things
    a bit better, Hopefully the mods can delete the original first post and replace it with Rusty-Nails link
    again thanks heap Rusty
  5. The Following User Says Thank You to threedogs For This Useful Post:
    Rocket55 (19th August 2015)
  6. #394
    84 Post(s)
    What is the thickness
    of the steel of
    your GQ recovery points,
    TD?
  7. #395
    12mm with 3 x 14mm bolts holding it in place,
    modelled off a series 1 single cab GU comp truck.
    Working on a 16mm two piece one that should fit both the GQ and some GUs
    Had some cut out of MDF to play with, that will be bullet proof lol
  8. The Following User Says Thank You to threedogs For This Useful Post:
    mudnut (19th August 2015)
  9. #396
    wooo just fitted my new recovery points. they look schmick! very fast postage, and excellent customer service! thanks john! also, do i need to replace the bolts? the ones i had i had to take out a washer, they were long enough to fit the flat and spring washer.
  10. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    Rossco (21st August 2015), threedogs (27th August 2015)
  11. #397
    Just a quick heads up thanks to Gregs a member here Ive been able to get my hands on a brand new Y62.
    I have a proto type front recovery point which will be getting cut next week. Turned out to be easier than I thought.
    Note this Y62 had no bullbar but I think it should work with a bullbar regardless of which make.
    now to watch the copy cats lol
  12. #398
    @ Rusty Those bolts look rusty I'd be changing them for grade 8 zinc plated.
    Its a lot of red eh lol
  13. The Following User Says Thank You to threedogs For This Useful Post:
    rusty_nail (27th August 2015)
  14. #399
    Patrol Guru TimE's Avatar
    Canberra
    3 Post(s)
    I used 50mm M12 high tensile (8.8) bolts 1.25 thread, got them from Repco, but Bunnings or any other hardware shop should have them. The original M12 (8.8) bolts are only 35mm long, not long enough.
    See my post 327 in this thread.
  15. The Following 3 Users Say Thank You to TimE For This Useful Post:
    Bloodyaussie (27th August 2015), rusty_nail (27th August 2015), threedogs (27th August 2015)
  16. #400
    Going to look at another Y62 tomorrow, so I'll grab some pics of the supercharged engine bay.
    This thing goes like a cut cat [fast] lol
