Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Dash Warning lights at the same time. Help.
    Aug 2015
    Question Dash Warning lights at the same time. Help.
    Today whilst driving my 04 GU three warning lights simultaneously lit up on my dash. The battery symbol (far right) exclamation in a circle (normally hand brake) and the orange Sub Tank (far left) lights all came on together. Very strange any thoughts or suggestions? Maybe alternator strangeness? help appreciated.
    Aug 2010
    adelaide
    sounds like an earthing strap has failed try putting a new one in
    OH LEATHER IS NICE
    Yeah when an alternator is failing it will do funny things with the dash lights.
    Are you able to test it?
    178 Post(s)
    Yep, I’ve experienced the same on another vehicle. It could just be that the brushes need replacing. That was the problem with mine & new brushes fixed the odd dash light issues.
  5. #5
    Yes mine had the diodes fail, so it would charge fine but drain the battery very quickly when not running.
    I had strange goings on with my dash lights too.
  6. #6
    That combo of lights is the classic symptom of a shagged Alternator, supply or sense wiring.
    They come on and stay on when the Alternator has low/no output.
    Check the voltage at the battery terminals or Alternator with the engine running and if it is below 13.8 ish then that will be the problem
  7. #7
    Funny though as mine would only come on at high revs.
  8. #8
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    As a veteran of two shagged alternators, I agree with the above. Watch out if you are getting the lights come on at high revs as stated by Winnie, in my case it was the regulator not working and the charge getting up to 19volts. Shagged the battery as well, but I had no option as I had to drive it home. If you have auto trans its a bugger as you have an electric interlock on the shifter. No battery, can't get it out of park.
  9. #9
    Last time all the dash lights came on I had a major malfunction with the Alternator.
    As for just changing brushes I think the comutator needs to be machined as well
    other wise you may only be charging using the edges of the brushes, which may charge
    at a higher than normal rate of charge.
    I now have 2 Baintech volt gauges on the centre facia so at a glance I can see if
    charge rate is eratic
  10. #10
    Hardcore
    central coast nsw
    Problem --dash lights, ALT GLOW & WATER TRAP, would come on for a bit and then go out.
    So I cleaned up the slip ring etc and new bearings problem went away.
    (Cant recall voltage)
    Later problem returned,
    symptoms---- dash lights on again & engle fridge won't run now, only getting about 9 volts load tested power @ fridge.
    Ok, power supply, voltage drop @ fridge.
    Now only getting only 12.3 volts via alt charge post directly to battery earth or chassis with a multi meter.
    Humm ok the alternator must be shagged,me thinks.
    Stripped alternator again, brushes look suss, heavy carbon deposits on one side causing brushes to stick.
    so going by thread, slip ring needs machining correctly and new brushes.
    Gave a quick tart up, but voltage still low & fridge wont run still.
    Still only 12.3 v @ alt again.
    stuff it, go the whole hog, new alternator.
    Now only 12.86 volts same test.
    So I now assume either the battery has an issue or wires as mentioned.
    At a glance @ the alt, wires looks ok doesn't look broken or corroded.
    about to check battery with hydrometer,
    but thinks it's alright, starting isn't an issue, car starts just fine.
    and battery seems to charge ok with my jaycar 15amp smart charger.
    What would be the problem I'm looking for with the wires exactly ?.
    S wire = feeds battery voltage back to the alternator reg.
    L = goes to dash light.
    And alternator post wire = charge wire for battery.
    Battery reading with hydrometer is ok
    pulled sense wire from alt plug looks a good clean connection.
    tested ohms reading back to 7.5amp fuse connection has zero resistance.
    then test to bat pos terminal zero resistance also.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
